I had the same issue. Converting my date field from long to date type fixed the issue.
Hello...thanks Jarrod for posting. I also experienced the same issue with a file geodatabase feature class published from ArcMap 10.4.1 to AGOL having zero records. My initial time field was a short integer representing year (e.g. 2016). I converted this into a Date field using the Convert Time Field tool in ArcMap, then enabled time on the layer from the properties by pointing to the new converted Date time field. Upon publishing this, I now had all time enabled records in AGOL.
