I am finding some errors in my region in the World Topo, Topographic, and Streets basemaps. What is the easiest way to correct the basemaps?
Thanks for your suggestions.
Here are the way to submit feedback to the different maps
Topographic Map feedback
Imagery Map feedback
Street Map feedback
Those came from this thread, but problems with the forum migration removed the links.
Thank you! So if it is the same error propagated through all 3 maps, do I need to edit each one? I appreciate your quick response, Ken!
I don't have a good answer on that. Hopefully, if the error is on a common data layer for in all three maps, giving feedback on a single map would make it to all three. Then again, depending on how often each of them are updated, it might work to your benefit to note the change in each one.
You can just report the issue once. Several basemaps utilize the same underlying source data, so it will be fixed across basemaps.
Mike
Hi Mike
Is the feedback for each of the basemaps read at the same frequency? Or is there a particular basemap that will get its feedback reviewed more often?
