"<BOL><UND>" + [Location_I] + "</UND></BOL>"
"<BOL><UND>" + [Location_I] + "</BOL></UND>"
Thank you!
Jeffrey Wittler | Environmental Resources Manager | Clark Public Utilities | p: 360.992.8577
Try:
<SPAN class="string token">"<BOL><UND>"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN>Section_Number<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"</UND></BOL>"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'\n '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN>Planned_Plants<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'\n '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN>Acres_numeric<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">' ac'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
You are closing the XML tags incorrectly. Instead of <UND>, you need </UND>.
New to Python (or for that matter VBScript). The instructions above seem straight forward but i am unable to get it to work. The following is what I've tried to do
"<BOL><UND>" + [Section_Number] + "<UND><BOL>" + '\n ' + [Planned_Plants] + '\n ' + [Acres_numeric] + ' ac'
That would hopefully produce the following result
1.3 ac
Below is the resulting label on my map:
<BOL><UND>3<UND><BOL>
I'm obviously missing something but unable to identify what I'm doing wrong. Any help would be much appreciated.
