When I have a featureAction in my widget, the onExecute method, when is executed?
I know that Is not when I open the widget, somebody knows when?
Rolando,
You have to build one yourself. You can look at the eSearch widget for an example of this.
Widget.html:
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"popup-menu-button esearch-result-action-button"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>event<SPAN class="operator token">=</SPAN><SPAN class="string token">"click:_onBtnMenuClicked"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>point<SPAN class="operator token">=</SPAN><SPAN class="string token">"divOptions"</SPAN> title<SPAN class="operator token">=</SPAN><SPAN class="string token">"${nls.resultactions}"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"display:none;"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
Widget.js:
_onBtnMenuClicked: function(evt){ var position = html.position(evt.target || evt.srcElement); var featureSet = this._getFeatureSet(); .....<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Robert, and how can I use a menu in the widget itself.?
When the custom FeatureAction is clicked. It depends if the FeatureAction is added to the popup menu or a menu in the widget itself.
