Yes. Give that a try
This error occurs if you use ArcGIS Flex Viewer 2.1 compiled widget with 2.2 Viewer.Try compiling your entire source with 2.2 (including all your widgets) This should fix this errorThere was change made in 2.2 to get rid of following warning that was reported in http://forums.arcgis.com/threads/13542-Flex-4.1-SDK-Warning-with-FlexViewer-2.1?highlight=warning"Description Resource Path Location Typecom.esri.viewer:BaseWidget is a module or application that is directly referenced. This will cause com.esri.viewer:BaseWidget and all of its dependencies to be linked in with index. Using an interface is the recommended practice to avoid this. flexviewer2.1 Unknown Flex Problem"Docs will be updated with this information.
Attached request and response didnt help. Do you have debug version of flash player? if not could you try installing debug version of the player so that it can throw runtime error to help figure out the cause.
Could you keep an eye on the http requests and response that are going through with tools such as firebug/httpfox fiddler so that when ever you see viewer not refreshing the map, its cause can be pinpointed.
