OS
CentOS 7
Qt versionQt: 5.8.0Qt Creator: 4.2.1
ContentWhen drawing a line with the GraphicsOverlay class, the map screen turns black when it is a solid line.* Dynamic only occurs.※ Please check the attached document for details.The symbol uses the SimpleLineSymbol class.
I tried this, but could not reproduce (tested on Ubuntu 16.04). Could you upload a small sample project that reproduces the issue? Also, are you able to reproduce the issue on any other platforms? As you might know already, CentOS isn't a supported platform of ours, but I'm guessing it should mostly behave the same as RHEL.
<SPAN class="keyword token">auto</SPAN> go <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">GraphicsOverlay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> go<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setRenderingMode</SPAN><SPAN class="punctuation token">(</SPAN>GraphicsRenderingMode<SPAN class="operator token">::</SPAN>Dynamic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">auto</SPAN> s <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbolStyle<SPAN class="operator token">::</SPAN>Solid<SPAN class="punctuation token">,</SPAN> <SPAN class="token function">QColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"black"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">auto</SPAN> sr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>s<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> go<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>sr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> m_mapView<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">graphicsOverlays</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">append</SPAN><SPAN class="punctuation token">(</SPAN>go<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">auto</SPAN> g <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> go<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">graphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">append</SPAN><SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">auto</SPAN> pb <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">PolylineBuilder</SPAN><SPAN class="punctuation token">(</SPAN>SpatialReference<SPAN class="operator token">::</SPAN><SPAN class="token function">webMercator</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>m_mapView<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>MapGraphicsView<SPAN class="operator token">::</SPAN>mouseClicked<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">=</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>QMouseEvent e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">auto</SPAN> p <SPAN class="operator token">=</SPAN> m_mapView<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">screenToLocation</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">x</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">y</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">addPoint</SPAN><SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> g<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setGeometry</SPAN><SPAN class="punctuation token">(</SPAN>pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">toPolyline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you for your information.
I tried on the small sample projects but an error occurred.
Sorry another platforms until is not tried.
Is Cent OS difficult?
Can you share your project with me please?
I do not know if this is related to the issue or not, but I just wanted to make you aware that CentOS is not one of our officially supported platforms. The officially supported platforms are listed here - System requirements—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
It still might work since it is similar to RHEL, but we have not done any testing on this platform.
