def main(): try: import arcpy, sys, traceback, os, glob arcpy.env.overwriteOutput = True masterFolder = r"C:\tmp\Shp" outputFolder = r"C:\tmp\Shp_merged" #collect a list of subfolders in master folder subfolderLst = os.listdir(masterFolder) #declare a dictionary where a key will be shapefile name #... and value a list of pathes to shapefile with this name in all subfolders shpDict = {} #loop through all subfolders for subfolder in subfolderLst: #check current subfolder and make a list of pathes to each .shp file shpLst = glob.glob(os.path.join(masterFolder,subfolder,'*.shp')) #add each shapefile path to dictionary for shpPath in shpLst: shpName = os.path.basename(shpPath) #if there's no dictioray key of shapefile name create one with empty list as value #... and append path to list if not shpName in shpDict: shpDict[shpName] = [] shpDict[shpName].append(shpPath) #if there's a dictionary key of shapefile name just append path to the list else: shpDict[shpName].append(shpPath) #Merge collected shapefiles into new shapefile #for each dictionary key use its value (pathes list) as an input to Merge tool for shapefile in shpDict: outShp = os.path.join(outputFolder, shapefile[:-4]+"_merge.shp") arcpy.Merge_management(shpDict[shapefile], outShp) print outShp + " created." except: print arcpy.GetMessages() # Get the traceback object '"' + wildcard + '"' tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate information together concerning the error into a # message string pymsg = tbinfo + "\n" + str(sys.exc_type)+ ": " + str(sys.exc_value) # Return python error messages for use with a script tool arcpy.AddError(pymsg) # Print Python error messages for use in Python/PythonWin print pymsg if __name__ == '__main__': main()
def main(): try: import arcpy, sys, traceback, os arcpy.env.overwriteOutput = True masterFolder = r"C:\tmp\Shp" outputFolder = r"C:\tmp\Shp_merged" #collect list of subfolders subfolderLst = os.listdir(masterFolder) #collect all subfolder suffixes into list suffixLst = [] for subfolder in subfolderLst: suffixLst.append(subfolder[-1]) #for each suffix walk through all subfolders and collect shp names to merge for sfx in suffixLst: shpToMergeLst = [] #emtpy list to collect shps to merge for subfolder in subfolderLst: arcpy.env.workspace = os.path.join(masterFolder, subfolder) #build path to workspace wildcard = "*" + sfx +".shp" #build wildcard to restrict search in next step shapefilesLst = arcpy.ListFeatureClasses(wildcard) #one element list with shp name #add full shp path to list (if shp exists in this subfolder) if shapefilesLst: shpToMergeLst.append(os.path.join(masterFolder,subfolder,shapefilesLst[0])) #merge collected shps into new folder if shpToMergeLst: outShp = os.path.join(outputFolder, os.path.basename(shpToMergeLst[0][:-4])+"_merge.shp") arcpy.Merge_management(shpToMergeLst, outShp) print outShp + " created." except: print arcpy.GetMessages() # Get the traceback object '"' + wildcard + '"' tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate information together concerning the error into a # message string pymsg = tbinfo + "\n" + str(sys.exc_type)+ ": " + str(sys.exc_value) # Return python error messages for use with a script tool arcpy.AddError(pymsg) # Print Python error messages for use in Python/PythonWin print pymsg if __name__ == '__main__': main()
Firstly I assume that 'filename' part of shapefile name is different in each subfolder (BTW, Merge tool wont allow for not unique names).
The folder names are completely independent to the file names. Unfortunately. Every subfolder within the master folder needs to be chchecked for the repeating file names.
for shapefile in shpDict: outFC = os.path.join(outputGDB, shapefile[:-4]+"_merge") arcpy.Merge_management(shpDict[shapefile], outFC) print outFC + " created."
