<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Using RelationshipInspector (view)"> <!-- Description: This sample demonstrates how to use the FeatureLayer to perform graphical selections, and then use that selection to view related records using the RelationshipInspector component. The first selection which is made by a single click on the map selects features in the FeatureLayer. The selected graphic is then assigned to the RelationshipInspector and the RelationshipInspector is assigned to the map's infoWindow content property. The graphic's location is then used to display the map's InfoWindow. Note: The RelationshipInspector is doing all the work here, if you want more control you can modify the default skin or check out the "Related Records" sample found under the "FeatureLayer" folder in the samples. This sample will look for related records in the TOPS table. In this case, the relations have been setup in ArcMap, and the relationships information made available in the Service Directory which lists two relationships. See http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer * a table - Tops: http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/2 * a point layer - Wells : http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0 Documentation: For more information, see the API documentation. http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/components/RelationshipInspector.html http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/events/FeatureLayerEvent.html http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/events/MapMouseEvent.html http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/Extent.html http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/MapPoint.html http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#mode http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#selectFeatures() http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/supportClasses/Query.html ArcGIS REST API documentation http://resources.arcgis.com/en/help/rest/apiref/queryrelatedrecords.html ArcGIS for Desktop documentation About relating tables http://resources.arcgis.com/en/help/main/10.1/index.html#/About_joining_and_relating_tables/005s0000002n000000/ Essentials of relating tables http://resources.arcgis.com/en/help/main/10.1/index.html#/Essentials_of_relating_tables/005s0000002t000000/ Relating the attributes in one table to another http://resources.arcgis.com/en/help/main/10.1/index.html#/Relating_the_attributes_in_one_table_to_another/005s0000002v000000/ --> <fx:Script> <![CDATA[ import com.esri.ags.events.FeatureLayerEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.tasks.supportClasses.Query; import mx.controls.Alert; private function findWells(event:MapMouseEvent):void { // find wells near the mouse click var tol:Number = map.extent.width / map.width * 5; var x:Number = event.mapPoint.x; var y:Number = event.mapPoint.y; var queryExtent:Extent = new Extent(x - tol, y - tol, x + tol, y + tol, event.mapPoint.spatialReference); var thisSelectionQuery:Query = new Query(); thisSelectionQuery.geometry = queryExtent; wellsLayer.selectFeatures(thisSelectionQuery, FeatureLayer.SELECTION_NEW); } private function wellsLayer_selectionCompleteHandler(event:FeatureLayerEvent):void { // check the first return feature to see if it has any related features if (event.features.length > 0) { map.infoWindow.content = relationshipInspector; relationshipInspector.infoWindowLabel = "ID: " + event.features[0].attributes["KID"]; relationshipInspector.graphic = event.features[0]; map.infoWindow.show(event.features[0].geometry as MapPoint); } else { map.infoWindow.hide(); Alert.show("No wells found here, please try somewhere else.", "No features"); } } ]]> </fx:Script> <fx:Declarations> <esri:RelationshipInspector id="relationshipInspector" width="300" height="300" editEnabled="true" /> </fx:Declarations> <s:controlBarContent> <s:RichText width="100%"> This sample demonstrates how to use the FeatureLayer to perform graphical selections, and then use that selection to view related records using the RelationshipInspector component. Click a well location to select and view its related record information. </s:RichText> </s:controlBarContent> <esri:Map id="map" mapClick="findWells(event)"> <esri:extent> <esri:Extent xmin="-10844058" ymin="4513057" xmax="-10837656" ymax="4516411"> <esri:SpatialReference wkid="102100"/> </esri:Extent> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <esri:ArcGISDynamicMapServiceLayer alpha="0.7" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer"> <esri:visibleLayers> <s:ArrayCollection> <fx:Number>0</fx:Number> <fx:Number>1</fx:Number> </s:ArrayCollection> </esri:visibleLayers> </esri:ArcGISDynamicMapServiceLayer> <esri:FeatureLayer id="wellsLayer" mode="selection" outFields="[KID]" selectionComplete="wellsLayer_selectionCompleteHandler(event)" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0"/> </esri:Map> </s:Application>
<esri:FeatureLayer id="wellsLayer" mode="selection" outFields="[KID]" selectionComplete="wellsLayer_selectionCompleteHandler(event)" url="http://yourServer/ArcGIS/rest/services/yourFolder/FeatureServer/0"/>
