The original data file that I have projected in ArcMap has only the lat, lon, time, date, and uid as attributes in chronological order. To do the speed filtering I need to calculate the distance between consecutive points then using this and the times calculate a rough estimate of speed.
Calculate the percentage increase of a numeric field. Parser: Python Expression: percentIncrease(float(!FieldA!)) Code Block: lastValue = 0 def percentIncrease(newValue): global lastValue if lastValue: percentage = ((newValue - lastValue) / lastValue) * 100 else: percentage = 0 lastValue = newValue return percentage
