Hi, khairul amri.
I can't also load the web scenes which I was able to do so before.
Details
Downloading: 0% (0 of 18.84 MB)
11ms: CE Web Viewer version: 3.10 [ 3.10.0.201511160532 | html:3.10.0.201511160532_ ]
29ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
SHADING_LANGUAGE_VERSION: WebGL GLSL ES 1.0 (OpenGL ES GLSL ES 1.0 Chromium)VENDOR: WebKitRENDERER: WebKit WebGLEXTENSIONS: ANGLE_instanced_arrays, EXT_blend_minmax, EXT_frag_depth, EXT_shader_texture_lod, EXT_sRGB, EXT_texture_filter_anisotropic, WEBKIT_EXT_texture_filter_anisotropic, OES_element_index_uint, OES_standard_derivatives, OES_texture_float, OES_texture_float_linear, OES_texture_half_float, OES_texture_half_float_linear, OES_vertex_array_object, WEBGL_compressed_texture_s3tc, WEBKIT_WEBGL_compressed_texture_s3tc, WEBGL_debug_renderer_info, WEBGL_debug_shaders, WEBGL_depth_texture, WEBKIT_WEBGL_depth_texture, WEBGL_draw_buffers, WEBGL_lose_context, WEBKIT_WEBGL_lose_contextMAX_TEXTURE_SIZE: 16384MAX_RENDERBUFFER_SIZE: 16384MAX_VERTEX_TEXTURE_IMAGE_UNITS: 16
425ms: Loading webscene id : d3177637843e4fd39517540834befd76
433ms: Fallback to custom unzip on arraybuffer and custom streamParser
6394ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/data
6395ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/data
6401ms: Downloading: 0% (0 of 18.84 MB)
Here's another one:
28ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
597ms: Loading webscene id : 97c5ee191b8e43ceb1b700309962e608
608ms: Fallback to custom unzip on arraybuffer and custom streamParser
6163ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/data
6163ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/data
6169ms: Downloading: 0% (0 of 8.54 MB)
CityEngine Web Viewer Help
I was able to properly open these web scenes just a few weeks back. What could be the reason(s) that they are not loading now? Thanks!
Marian Marigmen
I tried to download your data, and view through offline viewer,
here is the log :
29150ms: Loading scene file : Bonifacio_Final.3ws
29752ms: Using custom unzip and streamparser on arraybuffer
31197ms: Reading: 76% (16.63 of 22 MB)
31266ms: Invalid Web Scene (3ws) data clarinet parser error in Bonifacio_Final.3ws: Error: Max buffer length exceeded: textNode Line: 1 Column: 883400 Char:
seems your data is not valid or corrupted.
I'm having the same problem with the Web Scene that I have just created. And upon checking, all the web scenes that I have created before no longer loads properly in the web viewer.
How do I resolve this issue? My browser is updated, as well as my graphics drivers. Thanks!
562ms: Loading webscene id : eae2aa5ca6224631947cc9c5550b0262
569ms: Fallback to custom unzip on arraybuffer and custom streamParser
6613ms: Unable to load data : http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6613ms: Unable to load URL Error status 0 on http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6618ms: Downloading: 0% (0 of 11.16 MB)
25188ms: Reading: 98% (57.25 of 58.51 MB).
Hi Carlno setting required, this should work out of the box.Can you try the following:in the problematic scene* create a new shape layer "test" with a single shape* hide all other layers* start 3ws exporter, and set exported content to "export shapes only"* exclude all layers from being exported (uncheck in second export page) except "test"* does the problem still occur?* if so, can you post the problematic 3ws here so we can track the problem down?
Hi Matt,Thanks for your pointer, after switching off Street Network layer the model successfully exported. But now I need to figure out whats the problem in the shape geometry.Thanks.
I there a setting that I need to change to include the bookmarks?
