I'd like to change the central meridian of the projection for my map in ArcGIS pro. How can I do so?
Thanks in advance,
Greg
You could create a new coordinate system > Add the predefined C.S. and change the desired parameter.
How To: Create a custom projection file with units of feet or meters in ArcMap
In ArcGIS Pro, right click on the Map and select Properties. In the Coordinate Systems parameter, click the right Globe+ icon and select New Geographic Coordinate System or New Projected Coordinate System and modify the parameters for the new CS.
Hmmm... it appears that I only have the "import" option. I'm using ArcPro v1.4
Ah I see...with the release of ArcGIS Pro 2.0 in the next month or so, you'll have this functionality. You could use ArcMap to create a new *.prj and import it into ArcGIS Pro. Then it would be available in the 1.4 release.
Looking forward to the 2.0 release!!! Is it worth testing out the beta version of it?
