//////////////////////////////////////////////////////////////////////////////// // // Copyright (c) 2010-2011 Esri // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/License.txt // //////////////////////////////////////////////////////////////////////////////// package com.esri.viewer.utils { import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.geometry.Polyline; import mx.utils.StringUtil; public class GeoRSSUtil { private static const GEORSS:Namespace = Namespaces.GEORSS_NS; private static const GEO:Namespace = Namespaces.GEO_NS; private static const GML:Namespace = Namespaces.GML_NS; private static const GEOLL:Namespace = Namespaces.GEO_LL; public function GeoRSSUtil(singletonEnforcer:SingletonEnforcer) { } public static function toGeometry(x:XML):Geometry { var georssPoint:String = String(x.GEORSS::point); if (georssPoint) { return parseGeoRSSPoint(georssPoint); } var georssLine:String = String(x.GEORSS::line); if (georssLine) { return parseGeoRSSLine(georssLine); } var georssPolygon:String = String(x.GEORSS::polygon); if (georssPolygon) { return parseGeoRSSPolygon(georssPolygon); } var pointList:XMLList = x.GEO::point; if (pointList && pointList.length() > 0) { var geoPoint:XML = pointList[0]; var getLat:Number = Number(geoPoint.GEO::lat); var geoLon:Number = Number(geoPoint.GEO::long); return new MapPoint(geoLon, getLat); } //My Add var markerPoint:String = String(x.marker); if (markerPoint) { return parseGeoRSSPoint(markerPoint); } //End My Add var whereList:XMLList = x.GEORSS::where; if (whereList && whereList.length() > 0) { var pos:String = whereList[0].GML::Point[0].GML::pos[0]; var arr:Array = pos.split(" "); var gmlLat:Number = Number(arr[0]); var gmlLon:Number = Number(arr[1]); return new MapPoint(gmlLon, gmlLat); } var georssLat:String = String(x.GEOLL::lat); var georssLong:Number = Number(x.GEOLL::long); if ((georssLong) && (georssLat)) { return new MapPoint(Number(georssLong), Number(georssLat)); } return null; } private static function parseGeoRSSWhere(x:XML):Geometry { return null; } private static function parseGeoRSSPoint(text:String):Geometry { var tokens:Array = StringUtil.trim(text).split(" "); var lat:Number = Number(tokens[0]); var lon:Number = Number(tokens[1]); return new MapPoint(lon, lat); } private static function parseGeoRSSLine(text:String):Geometry { var path:Array = []; var tokens:Array = StringUtil.trim(text).split(" "); if (tokens.length > 3) { for (var i:int = 0, j:int = 1; j < tokens.length; i += 2, j += 2) { var lat:Number = Number(tokens); var lon:Number = Number(tokens); path.push(new MapPoint(lon, lat)); } } return new Polyline([ path ]); } private static function parseGeoRSSPolygon(text:String):Geometry { var path:Array = []; var tokens:Array = StringUtil.trim(text).split(" "); for (var i:int = 0, j:int = 1; j < tokens.length; i += 2, j += 2) { var lat:Number = Number(tokens); var lon:Number = Number(tokens); path.push(new MapPoint(lon, lat)); } return new Polygon([ path ]); } } } class SingletonEnforcer { }
Thanks. I will try this out. Does ESRI have any documentation on how to do this?
<s:HTTPService id="srv" result="srv_resultHandler(event)" url="here your url"/>
I am trying to use a GeoRSS feed that seems to be in geographic cooridantes so it will overlay in google maps. When I try and use this feed in the Flex Viewer it shows the points all over the world. Is there anything i can do to use this feed in the Flex Viewer? Thanks.http://ww2.tdot.state.tn.us/tsw/GeoRSS/TDOTConstructionGeorss.xml
