function initialize_container() { //alert('Container Initialized'); // create container var obj= getSWF("agsview3"); obj.height = getPageHeight() - streetviewHeight; var svh = streetviewHeight + "px"; var divTag = document.createElement("div"); divTag.id = "pano"; divTag.style.width = "100%"; divTag.style.height = svh; divTag.style.position = "absolute"; divTag.style.bottom = "0px"; divTag.style.right = "0px"; divTag.style.left = "0px"; divTag.innerHTML = '<div style="position: absolute; top: 20px; right: 20px; width: 100px; height: 36px; text-align: center; color: #000; z-index: 2; line-height: 36px;"><img width="20px" height="20px" src="assets/images/maximize-button.png" onclick="maximizeStreetView();" /></div>'; document.body.appendChild(divTag); addEvent(window, "resize", windowResized ); }
function maximizeStreetView() { try { var theDiv = document.getElementById("pano"); if(theDiv!=null) { var obj= getSWF("agsview3"); obj.height = "1"; theDiv.style.display = "block"; theDiv.style.height = "100%"; google.maps.event.trigger(panorama, 'resize'); } }catch(err){ alert(err); } }
Michelle,I have not seen an update on this widget for a good deal of time on the ESRI site...(the widget we have been updating as the FV releases change "was" titled: FrStreetView)I have attached the compiled widget that works for 3.1 viewer (at least for us). Let me know if you need the uncompiled code.Hope this helps.Eric VGurnee, IL
See highlighted missing items in index.html. The html that you provided is not what I provided as part of the download.
I think it has to do with index.swf file. What does this file do? It seems as if when I replace the index.html file and the index.swf file on a simple flex project or new project things work fine. However, one where I have a complex project that has already been started if I overwrite that index.swf file it won't work at all 😞 Any thoughts on this???
Tony I think you and I have the same issue. From Andrew's comment to me it sounds like you have the right assmumption for the clsid:. I've tried it both ways and still have the same issue....
Andrew, I copied the code from your post this morning and created a new index file. It's still not working for me. My Java savvy co-worker is on vacation this week so please bear with me. On line 104, is that a big grin or is it really "clsid:D27CDB6E..."? Any other thoughts?Tony
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en"> <head> <title>ArcGIS Viewer for Flex</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta name="description" content="Esri ArcGIS viewer for Flex"/> <meta name="keywords" content="Esri, ArcGIS, Flex Viewer"/> <meta name="author" content="Esri"/> <!-- Include CSS to eliminate any default margins/padding and set the height of the html element and the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as the percentage of the height of its parent container, which has to be set explicitly. Fix for Firefox 3.6 focus border issues. Initially, don't display flashContent div so it won't show if JavaScript disabled. --> <style type="text/css" media="screen"> html, body { height:100%; } body { margin:0; padding:0; overflow:auto; text-align:center; background-color: #ffffff; } object:focus { outline:none; } #flashContent { display:none; } </style> <!-- Enable Browser History by replacing useBrowserHistory tokens with two hyphens --> <!-- BEGIN Browser History required section > <link rel="stylesheet" type="text/css" href="history/history.css" /> <script type="text/javascript" src="history/history.js"></script> <! END Browser History required section --> <script type="text/javascript"> var isIElt9 = false; </script> <!--[if lt IE 9]> <script type="text/javascript"> isIElt9 = true; </script> <![endif]--> <script src="http://maps.googleapis.com/maps/api/js?sensor=false" type="text/javascript"></script> <script type="text/javascript" src="widgets/StreetView/streetview.js"></script> <script type="text/javascript"> var _gaq = _gaq || []; _gaq.push(['_setAccount', 'UA-26683112-1']); _gaq.push(['_trackPageview']); (function() { var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true; ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js'; var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s); })(); </script> <script type="text/javascript" src="swfobject.js"></script> <script type="text/javascript"> <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. --> var swfVersionStr = "11.1.0"; <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. --> var xiSwfUrlStr = "playerProductInstall.swf"; var flashvars = {}; var params = {}; params.quality = "high"; params.bgcolor = "#ffffff"; params.allowscriptaccess = "sameDomain"; params.allowfullscreen = "true"; var isAIR = navigator.userAgent.indexOf("AdobeAIR") != -1; if (isAIR || isIElt9) { // workaround for overlaying tool tips and other content when loaded into an AIR app // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818 params.wmode = "opaque"; } var attributes = {}; attributes.id = "agsview3"; attributes.name = "agsview3"; attributes.align = "middle"; swfobject.embedSWF( "index.swf", "flashContent", "100%", "100%", swfVersionStr, xiSwfUrlStr, flashvars, params, attributes); <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. --> swfobject.createCSS("#flashContent", "display:block;text-align:left;"); </script> </head> <body> <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show when JavaScript is disabled. --> <div id="flashContent"> <p> To view this page ensure that Adobe Flash Player version 11.1.0 or greater is installed. </p> <script type="text/javascript"> var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://"); document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='" + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" ); </script> </div> <noscript> <object id="agsview3" name="agsview3" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="100%" height="100%" id="index"> <param name="movie" value="index.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--[if !IE]>--> <object type="application/x-shockwave-flash" data="index.swf" width="100%" height="100%"> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--<![endif]--> <!--[if gte IE 6]>--> <p> Either scripts and active content are not permitted to run or Adobe Flash Player version 11.1.0 or greater is not installed. </p> <!--<![endif]--> <a href="http://www.adobe.com/go/getflashplayer"> <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" /> </a> <!--[if !IE]>--> </object> <!--<![endif]--> </object> </noscript> </body></html>
