Hi Raffi,Such effect might be caused by geometry generalization.Please try setting outputGeometryPrecision on the routeParameters object to zero. If it helps, try slightly increasing it to e.g. 2 meters (outputGeometryPrecision and outputGeometryPrecisionUnits params) - completely ungeneralized geometry can be a big payload.There is also a Default Output Geometry Precision parameter on the Network Analyst Server itself (in service properties, under Network Analysis capabilities), in case you do not want to pass the above parameters with every request.Dmitry
