I have the whole world DEM and a country's shapefile, how can I only get this country's DEM in Pro? Which tool to use? Intersect? Thanks
And if you intend to do any projection during or after the extraction process, make sure you read up on
How the Cell Size Projection Method environment setting works—Geoprocessing | ArcGIS Desktop
so that your data maintains some semblance of the original. If you are working with a raster and featureclass in decimal degrees, then the raster extent and cell size are the only things you need to consider. If you intend to project the raster then the projection method will be a factor
Hi Ke,
You will need the Spatial Analyst extension, and then you can use the Extract by Mask tool.
