<Grid.Resources> <esri:SimpleMarkerSymbol x:Key="DefaultMarkerSymbol" Color="Red" Size="6" Style="Diamond" /> </Grid.Resources> <esri:Map x:Name="map1" Background="White" WrapAround="True" Margin="0,22,0,0" Extent="-928323.6071, 502054.310, -295465.584, 1113500.0197" ZoomFactor="2" IsLogoVisible="False" > <!--Map Layers--> <esri:ArcGISTiledMapServiceLayer ID="BaseMapLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> <esri:GraphicsLayer ID="MyGraphicsLayer"> <esri:GraphicsLayer.MapTip> <Border BorderBrush="DarkGray" CornerRadius="13" BorderThickness="1" Margin="0,0,15,15"> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <Border CornerRadius="10" Background="#DDFFEEEE" BorderThickness="5" BorderBrush="#77FF0000"> <StackPanel Orientation="Vertical" HorizontalAlignment="Center" Margin="10"> <StackPanel Orientation="Horizontal"> <TextBlock Text="Cacao : " FontWeight="Bold" Foreground="#FF0F274E" FontSize="10" VerticalAlignment="Center" /> <TextBlock Text="{Binding [CACAO11_12]}" HorizontalAlignment="Left" VerticalAlignment="Center" /> </StackPanel> </StackPanel> </Border> </Border> </esri:GraphicsLayer.MapTip> </esri:GraphicsLayer> </esri:Map>
void MyMap_PropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e) { if (e.PropertyName == "SpatialReference") { map1.PropertyChanged -= MyMap_PropertyChanged; _legendGridCollapsed = false; _classGridCollapsed = false; LegendCollapsedTriangle.MouseLeftButtonUp += Triangle_MouseLeftButtonUp; LegendExpandedTriangle.MouseLeftButtonUp += Triangle_MouseLeftButtonUp; // Set query where clause to include features with an area greater than 70 square miles. This // will effectively exclude the District of Columbia from attributes to avoid skewing classifications. ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query() { Where = "CAFE11_12 > 0 and CACAO11_12 > 0", OutSpatialReference = map1.SpatialReference, ReturnGeometry = true }; query.OutFields.Add("*"); QueryTask queryTask = new QueryTask("http://services1.arcgis.com/yt621kzsRO05k21r/arcgis/rest/services/PRODUCTION_CACAO/FeatureServer/0"); queryTask.ExecuteCompleted += (evtsender, args) => { if (args.FeatureSet == null) return; _featureSet = args.FeatureSet; SetRangeValues(); _valeurSetRangeValue = true; }; queryTask.ExecuteCompleted += queryTask_ExecuteCompleted; queryTask.ExecuteAsync(query); CreateColorList1(); CreateThematicList(); } } void queryTask_ExecuteCompleted(object sender, QueryEventArgs queryArgs) { if (queryArgs.FeatureSet == null) return; FeatureSet resultFeatureSet = queryArgs.FeatureSet; ESRI.ArcGIS.Client.GraphicsLayer graphicsLayer = map1.Layers["MyGraphicsLayer"] as ESRI.ArcGIS.Client.GraphicsLayer; if (resultFeatureSet != null && resultFeatureSet.Features.Count > 0) { foreach (ESRI.ArcGIS.Client.Graphic graphicFeature in resultFeatureSet.Features) { graphicFeature.Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol; graphicsLayer.Graphics.Add(graphicFeature); } } }
GraphicsLayer l = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; TextBlock tb = new TextBlock(); Binding b = new Binding("[Location]"); tb.SetBinding(TextBlock.TextProperty, b); l.MapTip = tb;
void QueryTask_ExecuteCompleted(object sender, QueryEventArgs e) { foreach (var g in e.FeatureSet.Features) g.Attributes["Location"] = g.Geometry; // if not in the OutFields. }
I am also trying to define maptips from code behind. Jennifer, looking at your response, it seems to assume that you have created the graphics layer in XAML. I need to define everything in code-behind, the graphics layer, the template to display the maptip, the service to get the data from and getting the fields/data to display.
<esri:GraphicsLayer.MapTip> <TextBlock Text="{Binding [Location], FallbackValue=BindingFailed}"/> </esri:GraphicsLayer.MapTip>
private void GraphicsLayer_Initialized(object sender, EventArgs e) { GraphicsLayer l = sender as GraphicsLayer; TextBlock tb = new TextBlock(); Binding b = new Binding("[Location]"); tb.SetBinding(TextBlock.TextProperty, b); l.MapTip = tb; foreach (var g in l.Graphics) g.Attributes["Location"] = g.Geometry; }
