import flash.events.IOErrorEvent; import mx.collections.*; import flash.events.Event; import flash.net.FileFilter; import flash.net.FileReference; import flash.utils.ByteArray; private var fileRef:FileReference //File types which we want the user to open private static const FILE_TYPES:Array = [new FileFilter("Text File", "*.txt;*.text")]; private function doLoad():void{ fileRef = new FileReference(); //listen for when they select a file fileRef.addEventListener(Event.SELECT, onFileSelect); //listen for when then cancel out of the browse dialog fileRef.addEventListener(Event.CANCEL,onCancel); //open a native browse dialog that filters for text files fileRef.browse(FILE_TYPES); } /************ Browse Event Handlers **************/ //called when the user selects a file from the browse dialog private function onFileSelect(e:Event):void { //listen for when the file has loaded fileRef.addEventListener(Event.COMPLETE, onLoadComplete); //listen for any errors reading the file fileRef.addEventListener(IOErrorEvent.IO_ERROR, onLoadError); //load the content of the file fileRef.load(); } //called when the user cancels out of the browser dialog private function onCancel(e:Event):void { trace("File Browse Canceled"); fileRef = null; } /************ Select Event Handlers **************/ //called when the file has completed loading private function onLoadComplete(e:Event):void { //get the data from the file as a ByteArray var data:ByteArray = fileRef.data; var result:String = new String(fileRef.data); var record:Array = new Array(); var obj:Object; record = result.split(""); for (var i:int = 0; i< record.length; i++){ obj = new Object(); obj.street = record; addressDataImported.addItem(obj); } // addressDataImported.addItem({street:"test street"}); //read the bytes of the file as a string and put it in the //textarea //outputField.text = data.readUTFBytes(data.bytesAvailable); //clean up the FileReference instance fileRef = null; } //called if an error occurs while loading the file contents private function onLoadError(e:IOErrorEvent):void { trace("Error loading file : " + e.text); }
<mx:DataGrid id="dg1" dataProvider="{addressDataImported}" scroll="true" width="100%" height="150" itemClick="onItemClick(event)" itemRollOver="onItemRollOver(event)" itemRollOut="onItemRollOut(event)"> <mx:columns> <mx:DataGridColumn dataField="street" headerText="Street" width="55"/> </mx:columns> </mx:DataGrid>
