Hello,Adding kmz/kml directly to Esri Maps for SharePoint is not supported, but you could create a map in ArcGIS Online and then open/add that map in either the Esri Maps Web Part (JavaScript) or ArcGIS Map Web Part (Silverlight). Hope that helps,Katy
I have tried this and the kmz layer does not render in either the ArcGIS web part or the ESRI wed part. The map does render.I am on an SP site with HTTPS enabled and I have followed the instructions to set things up for this scenario but there is a Layer Initialization error - the language in the error references a security exception.Has anyone come across this?ThanksPaul
