12-21 22:38:59.498: E/AndroidRuntime(3011): FATAL EXCEPTION: main 12-21 22:38:59.498: E/AndroidRuntime(3011): java.lang.IllegalStateException: Graphics layer is not bounded to a map! 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.GraphicsLayer.nativeGetGraphicsAt(Native Method) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.GraphicsLayer.getGraphicIDs(Unknown Source) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.GraphicsLayer.getGraphicIDs(Unknown Source) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.arcgis.android.samples.attributeeditor.AttributeEditorActivity$2.onSingleTap(AttributeEditorActivity.java:148) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.MapOnTouchListener.onSingleTap(Unknown Source) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.MapGestureDetector$a.onSingleTapConfirmed(Unknown Source) 12-21 22:38:59.498: E/AndroidRuntime(3011): at android.view.GestureDetector$GestureHandler.handleMessage(GestureDetector.java:281) 12-21 22:38:59.498: E/AndroidRuntime(3011): at android.os.Handler.dispatchMessage(Handler.java:99) 12-21 22:38:59.498: E/AndroidRuntime(3011): at android.os.Looper.loop(Looper.java:137) 12-21 22:38:59.498: E/AndroidRuntime(3011): at android.app.ActivityThread.main(ActivityThread.java:4514) 12-21 22:38:59.498: E/AndroidRuntime(3011): at java.lang.reflect.Method.invokeNative(Native Method) 12-21 22:38:59.498: E/AndroidRuntime(3011): at java.lang.reflect.Method.invoke(Method.java:511) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:790) 12-21 22:38:59.498: E/AndroidRuntime(3011): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557) 12-21 22:38:59.498: E/AndroidRuntime(3011): at dalvik.system.NativeStart.main(Native Method)
public void onSingleTap(float x, float y) { // convert event into screen click pointClicked = mapView.toMapPoint(x, y); // build a query to select the clicked feature Query query = new Query(); query.setOutFields(new String[] { "*" }); query.setSpatialRelationship(SpatialRelationship.INTERSECTS); query.setGeometry(pointClicked); query.setInSpatialReference(mapView.getSpatialReference()); // call the select features method and implement the callbacklistener featureLayer.getGraphicIDs(x, y, 15); featureLayer.selectFeatures(query, ArcGISFeatureLayer.SELECTION_METHOD.NEW, new CallbackListener<FeatureSet>() { // handle any errors public void onError(Throwable e) { Log.d(TAG, "Select Features Error" + e.getLocalizedMessage()); } public void onCallback(FeatureSet queryResults) { if (queryResults.getGraphics().length > 0) { Log.d(TAG, "Feature found id=" + queryResults.getGraphics()[0].getAttributeValue(featureLayer.getObjectIdField())); // set new data and notify adapter that data has changed listAdapter.setFeatureSet(queryResults); listAdapter.notifyDataSetChanged(); // This callback is not run in the main UI thread. All GUI // related events must run in the UI thread, // therefore use the Activity.runOnUiThread() method. See // http://developer.android.com/reference/android/app/Activity.html#runOnUiThread(java.lang.Runnable) // for more information. AttributeEditorActivity.this.runOnUiThread(new Runnable() { public void run() { // show the editor dialog. showDialog(ATTRIBUTE_EDITOR_DIALOG_ID); } }); } } }); }
