I have a webmap created that contains 10 AGO hosted feature layers and 2 related tables. Everything is set up according to the documentation ( https://doc.arcgis.com/en/collector/android-phone/help/offline-prep.htm ) as far as I can tell. At the moment, myself and another user are having trouble downloading the map in Collector Classic as well as downloading Map Areas in Field Maps and ArcGIS Collector.
In Collector Classic, when I tap download in the bottom right corner of the card I receive an error message that reads
The map failed to download with the message: Unable to create replica. Please check your parameters., Exporting data for layer 0 failed.
In Field Maps, when I click on Add map area I receive a message that reads
an error occurred downloading map area
Does anyone have any guidance on what could be causing this issue? The only thing that I have read about is the potential for issues with the related tables but when I remove those tables from the web map - the issue persists.
