Hi! I've a problem importing a standalone table with coordinates x,y,z of 4 points.
To visualize the points I use Display XY Data, in the window on the right I compile the fields with the coordinates, the firts problem when I select the Coordinate System is the warning "No vertical coordinate system defined" so I define the vertical system too.
Then when I click on run, I don't see any warning, but the points are imported without the Z coordinate, and I really don't know why, and what I'm doing wrong.
I attach the table with the data, that are in Coordinates System 3003
Thank you
