When running the Zonal Histogram tool, the Results window say the tool executes successfully after 4.5 hours, but the output table is not created. Right clicking on the output table in the Results window gives the options "add to display" and "copy location"; the first does nothing and the second has the right path and filename but the file doesn't exist.Here's the really puzzling part: There are no error messages. Has anyone run into this before?I've tried Zonal Histogram many different ways for this task, and nothing works well. Outputting to a table in a file gdb worked once, but then ArcMap and ArcCatalog choke trying to export the output table to DBF.Details:ArcGIS 10 sp4Input zones: a layer that is a subset of polygons from a polygon shapefileInput raster: a large (16 GB) IMG rasterdesired output table: DBF file stored to a directory (not a geodatabase). Table should have 251 fields (yes, carefully chosen to respect the 255 field limit for dbf).
Hi James, ... Also, the tool might fail with some formats (including dbf and info table) if a graph was being specified. So could you please first try to see what happens if you specify a graph name?
Just to make sure I understand the point about the graph name--I was not requesting a graph, just the table. Do you mean that specifying a graph name and having the tool calculate and save it might help? Or just that if I were requesting a graph, then there would be naming issues.Thanks,Jim
Hi, I was the same problem, and I use this solution arcgis 10.0 - zonal histogram fails to create output table when looping - Geographic Information Systems Stack Exchange
