CountMe(%Row Count%)
def CountMe(n): import arcpy if n > 0: return "true" else: return "false"
def CountMe(n): if n > 0: return True else: return False
import arcpy rowcount = int(arcpy.GetParameterAsText(0)) if rowcount >= 1: arcpy.SetParameterAsText(1, "True") arcpy.SetParameterAsText(2, "False") arcpy.AddMessage("Rows Exist, updating table") elif rowcount == 0: arcpy.SetParameterAsText(1, "False") arcpy.SetParameterAsText(2, "True") arcpy.AddMessage("0 rows, updating table") else: arcpy.AddMessage("Code Didn't Work") del rowcount
import os, stat if os.path.isfile(infile): # checks if exists, otherwise get error if checking size on non-exist file os.stat(infile)[stat.ST_SIZE] ## returns size of file 0L if empty else: print "file not exist"
I just did something similar to this yesterday. I have a test model and a code that might be a good reference. I just created 2 tables with different row counts to test and used a model parameters as input :import arcpy rowcount = int(arcpy.GetParameterAsText(0)) if rowcount >= 1: arcpy.SetParameterAsText(1, "True") arcpy.SetParameterAsText(2, "False") arcpy.AddMessage("Rows Exist, updating table") elif rowcount == 0: arcpy.SetParameterAsText(1, "False") arcpy.SetParameterAsText(2, "True") arcpy.AddMessage("0 rows, updating table") else: arcpy.AddMessage("Code Didn't Work") del rowcount
