Layer 'MyService - MyLayer'seems to be on an internal network and is not accessible to ArcGIS.com. Thus, editing will be disabled on this layer.
I am having the same problem but only with Internet Explorer, when I use Firefox it works fine!
Firefox asks for my login but still show disabled editing error message after logging in. Any updates from people on this?
Hi Brandon,
Are you using an ArcGIS Server Service? If so, what kind of security is enabled on your service?
Editting an ArcGIS Server based Feature Services with Web Tier Authentication is not supported functionality in ArcGIS Online.Token based Security will allow editing through ArcGIS Online.
ArcGIS Server web services—ArcGIS Online Help | ArcGIS
If the service is a hosted feature service, please ensure that editing is turned on on the layer or in the web map.
Kelly
Hi Kelly,
Thank you for the information. We do use web tier authentication but it seems like our reasons for why have changed. I plan to switch to token and see if the issue is resolved.
Best,
Brandon
I made the switch and now when I look at the service details it asks me to login. And unfortunately none of my logins seem to work. My guess is there are some other settings I need to change to support token based security. Do you know of set-up documentation I could look at prior to submitting an esri ticket? Is it in the link you provided before?
I thought all was lost, until I saw your response, and remembered I agreed to UAT IE for our organisation. I switched browsers to FireFox and Voila! that strange error about internal networks not being accessible and editing disabled disappeared!
