Via the Catalog Window (in ArcMap) right-click on the script tool and choose Item Description from the context window. The choose edit.Jeff
Go to Catalogue. In the Catalogue tree, scroll to the bottom to Arctoolbox. Add your tool there like you did in the Arctoolbox window. When you have added it, highlight it and then choose the "Description" tab in the display window and then click on "edit". You will see the parameters in there. Click the drop down and add your tool description in the "Dialogue Explanation" box. You can also add a script explanation and many other metedata items.Mike
Hi Mehmet,I have never done this before but I think the solution is:1- create a compiled help system for your tool:http://support.esri.com/en/knowledgebase/techarticles/detail/276812 - embed it into the properties of the scripthttp://support.esri.com/en/knowledgebase/techarticles/detail/27690I wish the solution was more straightforward for a simple task like this. Let me know, if you have further questions.Caglar
