I want to get the usernames for the portal userid's that I am displaying in my simple table in WAB application. Any ideas?
Thank you!
This is how I set a text box (ownername) to the user's name (using the class 'jimu/portalUtils')
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_portal <SPAN class="operator token">=</SPAN> portalUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getPortal</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>appConfig<SPAN class="punctuation token">.</SPAN>portalUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>ownerName<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'value'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_portal<SPAN class="punctuation token">.</SPAN>user<SPAN class="punctuation token">.</SPAN>username<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
where should I put these lines of code to see the username?
