for files in glob.glob('%s.*' %name):
import arcgisscripting, os, glob, zipfile from os import path as p # Create the Geoprocessor object gp = arcgisscripting.create() # arcpy.overwriteOutput = True gp.overwriteoutput=1 def ZipShapes(path, out_path): gp.workspace = path shapes = gp.ListFeatureClasses("*") # iterate through list of shapefile for shape in iter(shapes.next, None): name = p.splitext(shape)[0] print name zip_path = p.join(out_path, name + '.zip') zip = zipfile.ZipFile(zip_path, 'w', zipfile.ZIP_DEFLATED) os.chdir(path) for files in glob.glob('%s*' %name): zip.write(p.join(path,files), files) print 'All files written to %s' %zip_path zip.close() if __name__ == '__main__': path = r'T:\\cotiss\CobleJ\shape2zip\address' outpath = r'T:\\cotiss\CobleJ\shape2zip\Shape_outputs' ZipShapes(path, outpath)
import sys, os, string, arcgisscripting, fnmatch from os import path as p import zipfile # Create the Geoprocessor object gp = arcgisscripting.create() # arcpy.overwriteOutput = True gp.overwriteoutput=1 def ZipShapes(path, out_path): gp.workspace = path shapes = gp.ListFeatureClasses("*") # iterate through list of shapefiles #for shape in shapes: for shape in iter(shapes.next, None): name = p.splitext(shape)[0] print name zip_path = p.join(out_path, name + '.zip') zip = zipfile.ZipFile(zip_path, 'w', zipfile.ZIP_DEFLATED) for path, dirs, files in os.walk(path): for f in files: if fnmatch.fnmatch(f, '%s*' %shape): zip.write(p.join(path,f), f) print 'All files written to %s' %zip_path zip.close() if __name__ == '__main__': path = r'T:\\cotiss\CobleJ\shape2zip\address' outpath = r'T:\\cotiss\CobleJ\shape2zip\Shape_outputs' ZipShapes(path, outpath)
I get the error, "NameError: global name 'zipflie' is not defined".
zip = zipfile.ZipFile(zip_path, 'w', zipfile.ZIP_DELFLATED)
import sys, os, string, arcgisscripting, fnmatch from os import path as p import zipfile # Create the Geoprocessor object gp = arcgisscripting.create() # arcpy.overwriteOutput = True gp.overwriteoutput=1 def ZipShapes(path, out_path): gp.workspace = path shapes = gp.ListFeatureClasses("*") # iterate through list of shapefiles #for shape in shapes: for shape in iter(shapes.next, None): name = p.splitext(shape)[0] print name zip_path = p.join(out_path, name + '.zip') zip = zipfile.ZipFile(zip_path, 'w', zipflie.ZIP_DELFLATED) for path, dirs, files in os.walk(path): for f in files: if fnmatch.fnmatch(f, '%s*' %shape): zip.write(p.join(path,f), f) print 'All files written to %s' %zip_path zip.close() if __name__ == '__main__': path = r'T:\\cotiss\\CobleJ\\shape2zip\\address' outpath = r'T:\\cotiss\\CobleJ\\shape2zip\\Shape_outputs' ZipShapes(path, outpath)
import fnmatch, os for shape in shapes: name = p.splitext(shape)[0]: zip_path = p.join(out_path, name + '.zip') zip = zipfile.ZipFile(zip_path, 'w', zipfile.ZIP_DEFLATED) zip.write(p.join(path,shape), shape) for path, dirs, files in os.walk(path): for f in files: if fnmatch.fnmatch(f, '%s*' %shape): zip.write(p.join(path,f), f) print 'All files written to %s' %zip_path zip.close()
gp = arcgisscripting.create(9.3)
One thing I noticed, though is that it did not actually compress the files (they were archived in zip files but not compressed).
import arcpy, os from os import path as p import zipfile arcpy.overwriteOutput = True def ZipShapes(path, out_path): arcpy.env.workspace = path shapes = arcpy.ListFeatureClasses() # iterate through list of shapefiles for shape in shapes: name = p.splitext(shape)[0] print name zip_path = p.join(out_path, name + '.zip') zip = zipfile.ZipFile(zip_path, 'w') zip.write(p.join(path,shape), shape) for f in arcpy.ListFiles('%s*' %name): if not f.endswith('.shp'): zip.write(p.join(path,f), f) print 'All files written to %s' %zip_path zip.close() if __name__ == '__main__': path = r'C:\Shape_test\Census_CedarCo' outpath = r'C:\Shape_outputs' ZipShapes(path, outpath)
