Hi guys, I have an error when I try to consolidate my project package. It already used the Analyse pro tool and fixed the python error, but still, have this problem.
You have a warning in the 2nd image.. what was it?
The error message
http://pro.arcgis.com/en/pro-app/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-and-warnings-01651-01675-001659.htm
suggests a syntax error, an incompatibility issue or missing data as the reasons.
Was the toolbox moved prior to consolidating?
Have you checked the script for errors or dependencies?
Is there only one script in the toolbox?
Any system scripts?
You also seem to have a basemap showing.
This caused an issue in at least one thread
https://community.esri.com/message/448522?commentID=448522#comment-448522
Hello Dan ,
There is still a problem with the consolidation.
I am still looking for a way to consolidate the toolbox inside the project.
ArcGIS Pro SDK Python
Sorry, I had questions, but I take it that your response would be a no to all and the threads didn't help.
What do you mean with moved prior consolidating?
I have created a new toolbox and copy all the python tools to the new one, however, it did not work.
I have checked it using the tool
I have 6 phyton tools Analise tool for pro.
I showed me some error in my python scripts that I fixed. Now It did not show me anything else. However, it still does not work.
What do you mean by system scripts?
Other than the python tools, I don't have anything else.
Also, I have tried to use the consolidate project tool. I did not work.
Just tested one of my toolboxes.
My project structure is pretty typical. Everything I need goes into one folder,
If your project structure differs or you have history associated with it, then that may be the unknown source of the errors.
Good luck. If it doesn't work, then zip you stuff and sent to Tech Support for further analysis
Error message url http://pro.arcgis.com/en/pro-app/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-and-warnings-01676-01700-001685.htm
leading me more to think you should examine your script, and delete your history
Do you know how I can contact to tech support?
Yes, that is the weird part, I have examined my python code using the analyze tool for Pro but it did not work.
Thank!
At the top of the page there is ... Support .... on the line with the Esri logo...that is the main access point
Cesar, did you get a case number or a resolution on this?
