How to select all rows of FeatureTable 4.16 after it loads?
featureTable<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"state"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>state<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"ready"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryObjectIds</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>ids<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> featureTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectRows</SPAN><SPAN class="punctuation token">(</SPAN>ids<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This worked like a charm. Thank you so much Robert Scheitlin, GISP
Robert, how can you add a checkbox at the column header so I can use it as select/deselect all records.
