I stumbled upon this old post while working on a similar project and was able to get Jeff's code to work for the first function(convertSPtoLL_LLC) by adding in the false northing variable and Y coordinate correction.
New lines are in red.
One of the original sources is John Snyder's Map Projections: A Working Manual. It also contains the state plane parameter values (NAD83 changes from NAD27 are listed in an appendix). If you use Jeff Pace's code as a template, please note that the "map units" of the first section are in US survey feet, not meters.Melita
is washington south transverse mercator or lambert?
org.mymanatee.common.latlong.convertWebMercAuxtoLL = function (uX,uY) { //code completely borrowed from http://www.frosties.com/index.php?option=com_mojo&Itemid=45&p=7 // lat and long backwards on link for some reason //alert("IN CONVERSION"); var x = uX; // alert("IN CONVERSION2"); var y = uY; var num3 = x / 6378137.0; var num4 = num3 * 57.295779513082323; //alert("IN CONVERSION3"); var num5 = Math.floor(((num4 + 180.0) / 360.0)); var num6 = num4 - (num5 * 360.0); //alert("IN CONVERSION4"); var num7 = 1.5707963267948966 - (2.0 * Math.atan(Math.exp((-1.0 * y) / 6378137.0))); var lon = num6; var lat = num7*57.295779513082323; // alert([lat,lon]); return [lat,lon]; }; org.mymanatee.common.latlong.convertLLtoWebMercAux = function (lat,lon) { //code completely borrowed from Dr Bill Hazelton's HP-33S calculator // http://homepage.mac.com/nwjh/HP-33S/ 10-Feb-10 //code completely borrowed from Dr Bill Hazelton's HP-33S calculator // http://homepage.mac.com/nwjh/HP-33S/ 10-Feb-10 var num = lon * 0.017453292519943295; var x = 6378137.0 * num; var a = lat * 0.017453292519943295; var mercatorX = x; var mercatorY = 3189068.5*Math.log((1.0 + Math.sin(a))/(1.0 - Math.sin(a))); // alert(londd); return [mercatorX,mercatorY]; };
I know that I can use the geometryService to convert between 2 different coordinate systems, but I'd like to reduce the number of calls made to the server to update coordinates. I'm trying to convert from wkid 32149 (NAD_1983_StatePlane_Washington_South_FIPS_4602) to Latitude/Longitude 4326. Does anyone know where I can find the math so I can create my own function to convert the coordinates? I've tried my Google Kung Fu, but come up dry.
/* * To change this template, choose Tools | Templates * and open the template in the editor. */ dojo.provide("org.mymanatee.common.latlong"); dojo.require("dojo.string"); org.mymanatee.common.latlong.convertSPtoLL_LLC = function (uX,uY) { var a = 20925604.48; //major radius of ellipsoid, map units (NAD 83) var ec = 0.08181905782; //eccentricity of ellipsoid (NAD 83) var angRad = 0.01745329252; //number of radians in a degree var pi4 = Math.PI / 4; //Pi / 4 var p0 = 24.333333 * angRad; //latitude of origin var p1 = 24.333333 * angRad; //latitude of first standard parallel var p2 = 31.5 * angRad; //latitude of second standard parallel var m0 = -82.000000 * angRad; //central meridian var x0 = 656166.666667; //False easting of central meridian, map units // Calculate the coordinate system constants. with (Math) { var m1 = cos(p1) / sqrt(1 - (pow(ec,2)) * pow(sin(p1),2)); var m2 = cos(p2) / sqrt(1 - (pow(ec,2)) * pow(sin(p2),2)); var t0 = tan(pi4 - (p0 / 2)); var t1 = tan(pi4 - (p1 / 2)); var t2 = tan(pi4 - (p2 / 2)); t0 = t0 / pow(((1 - (ec * (sin(p0)))) / (1 + (ec * (sin(p0))))),ec/2); t1 = t1 / pow(((1 - (ec * (sin(p1)))) / (1 + (ec * (sin(p1))))),ec/2); t2 = t2 / pow(((1 - (ec * (sin(p2)))) / (1 + (ec * (sin(p2))))),ec/2); var n = log(m1 / m2) / log(t1 / t2); var f = m1 / (n * pow(t1,n)); var rho0 = a * f * pow(t0,n); // Convert the coordinate to Latitude/Longitude. // Calculate the Longitude. var uX = uX - x0; var pi2 = pi4 * 2; var rho = sqrt(pow(uX,2) + pow((rho0 - uY),2)); var theta = atan(uX / (rho0 - uY)); var txy = pow((rho / (a * f)),(1 / n)); var lon = (theta / n) + m0; var uX = uX + x0; // Estimate the Latitude var lat0 = pi2 - (2 * atan(txy)); // Substitute the estimate into the iterative calculation that // converges on the correct Latitude value. var part1 = (1 - (ec * sin(lat0))) / (1 + (ec * sin(lat0))); var lat1 = pi2 - (2 * atan(txy * pow(part1,(ec/2)))); while ((abs(lat1 - lat0)) > 0.000000002) { lat0 = lat1; part1 = (1 - (ec * sin(lat0))) / (1 + (ec * sin(lat0))); lat1 = pi2 - (2 * atan(txy * pow(part1,(ec/2)))); } // Convert from radians to degrees. var Lat = lat1 / angRad; var Lon = lon / angRad; //alert(Lat); //alert(Lon); //Round the latitude and longitude //lat = (CLng(lat * 100000)) / 100000; //lon = (CLng(lon * 100000)) / 100000; Lat = Lat.toPrecision(7); Lon = Lon.toPrecision(8); return [Lat,Lon]; } }; //End of Code for converting map units to decimal degrees. //COnversion to LL from State Plane for Florida West (Transverse mercator, not Lamberic org.mymanatee.common.latlong.convertSPtoLL_TM = function (uX,uY) { //code completely borrowed from Dr Bill Hazelton's HP-33S calculator // http://homepage.mac.com/nwjh/HP-33S/ 10-Feb-10 var metconv = 1200/3937; //exact survey feet to meters var uXm = uX*metconv; var uYm = uY*metconv; var a = 6378137.000000000000000000; // semimajor axis from ESRI var b = 6356752.314140356100000000; // semiminor axis from ESRI var e2 = ((a*a)-(b*b))/(a*a);//ellipsoid var p0 = 24.333333; //latitude of origin var m0 = -82.000000; //central meridian in degrees var x0 = 656166.666667; //False easting of central meridian, map units var y0 = 0; //False Northing var k0 = 0.999941; //central scale factor k0 var x0m = x0*metconv; var y0m = y0*metconv; var p0rad = p0*Math.PI/180; var m0rad = m0*Math.PI/180; var e = Math.sqrt(e2); var b = a * Math.sqrt(1-e2); var n = (a - b)/(a + b); var G = a*(1-n)*(1-(n*n))*(1+2.25*(n*n)+225/64*(n*n*n*n))*Math.PI/180; var A0 = 1-e2/4-3*(e2*e2)/64-5*(e2*e2*e2)/256; var A2 = 3/8*(e2+(e2*e2)/4+15*(e2*e2*e2)/128); var A4 = 15/256*((e2*e2)+0.75*(e2*e2*e2)); var A6 = 35*(e2*e2*e2)/3072; var lat0 = p0rad; var m0atlat0 = a*(A0*lat0-A2*Math.sin(2*lat0)+A4*Math.sin(4*lat0)-A6*Math.sin(6*lat0)) var NminusNo = uYm - y0m; var m = m0atlat0+NminusNo/k0; var s = (m/G)*Math.PI/180; var fpl1 = (1.5*n-27*(n*n*n)/32)*Math.sin(2*s); var fpl2 = (21*(n*n)/16-55*(n*n*n*n)/32)*Math.sin(4*s); var fpl3 = 151*(n*n*n)/96*Math.sin(6*s); var fpl4 = 1097*(n*n*n*n)/512*Math.sin(8*s); var footptlat = (s+fpl1+fpl2+fpl3+fpl4); var rho = a*(1-e2)/Math.pow((1-e2*Math.sin(footptlat)*Math.sin(footptlat)),1.5); var nu = a/(Math.sqrt(1-e2*Math.sin(footptlat)*Math.sin(footptlat))); var psi = nu/rho; var t = Math.tan(footptlat); var E = uXm-x0m; var x = E/k0/nu; var lat1 = x*E/2; var lat2 = (x*x*x)*E/24*(-4*psi*psi+9*psi*(1-t*t)+12*t*t); var lat3 = (x*x*x*x*x)*E/720*(8*(psi*psi*psi*psi)*(11-24*(t*t))-12*(psi*psi*psi)*(21-71*(t*t))+15*(psi*psi)*(15-98*(t*t)+15*(t*t*t*t))+180*psi*(5*(t*t)-3*(t*t*t*t))+360*(t*t*t*t)); var lat4 = (x*x*x*x*x*x*x)*E/40320*(1385+3633*(t*t)+4095*(t*t*t*t)+1575*(t*t*t*t*t*t)); var lat = footptlat-(t/k0/rho)*(lat1-lat2+lat3-lat4); var latdd = lat*180/Math.PI; var w1 = x/Math.cos(footptlat); var w2 = Math.pow(-1*x,3)/6*(psi+2*t*t)/Math.cos(footptlat); var w3 = Math.pow(x,5)/120/Math.cos(footptlat)*(-4*(psi*psi*psi)*(1-6*(t*t))+(psi*psi)*(9-68*(t*t))+72*(psi)*(t*t)+24*(t*t*t*t)); var w4 = Math.pow(-1*x,7)/5040/Math.cos(footptlat)*(61+662*(t*t)+1320*(t*t*t*t)+720*(t*t*t*t*t*t)); var w = w1+w2+w3+w4; var lon = (-1*m0)*Math.PI/180-w; var londd = (-1*lon)*180/Math.PI; // alert(londd); return [latdd,londd]; }; org.mymanatee.common.latlong.convertLLtoSP_TM = function (lat,lon) { var metconv = 1200/3937; //exact survey feet to meters var a = 6378137.000000000000000000; // semimajor axis from ESRI var b = 6356752.314140356100000000; // semiminor axis from ESRI var e2 = ((a*a)-(b*b))/(a*a);//ellipsoid var p0 = 24.333333; //latitude of origin var m0 = -82.000000; //central meridian in degrees var x0 = 656166.666667; //False easting of central meridian, map units var y0 = 0; //False Northing var k0 = 0.999941; //central scale factor k0 var e = Math.sqrt(e2); var lat0rad_lat0=p0*Math.PI/180; var latrad_lat=lat*Math.PI/180; var rho_lat=a*(1-e2)/Math.pow((1-e2*Math.sin(latrad_lat)*Math.sin(latrad_lat)),1.5); // rho_lat0=a*(1-e2)/Math.pow((1-e2*Math.sin(lat0rad_lat0)*Math.sin(lat0rad_lat0)),1.5); not used var nu_lat=a/(Math.sqrt(1-e2*Math.sin(latrad_lat)*Math.sin(latrad_lat))); // nu_lat0=a/(Math.sqrt(1-e2*Math.sin(lat0rad_lat0)*Math.sin(lat0rad_lat0))); not used var omega_lat=((lon)*Math.PI/180)-((m0)*Math.PI/180); //provide negative lon so no negative multiplier // omega_lat0=""; not used var psi_lat=nu_lat/rho_lat; // psi_lat0=""; not used var t_lat=Math.tan(latrad_lat); // t_lat0=""; not used var a0_lat=1-e2/4-3*e2*e2/64-5*e2*e2*e2/256; var a2_lat=3/8*(e2+e2*e2/4+15*e2*e2*e2/128); var a4_lat=15/256*(e2*e2+0.75*e2*e2*e2); var a6_lat=35*e2*e2*e2/3072; var mlat_lat=a*(a0_lat*latrad_lat-a2_lat*Math.sin(2*latrad_lat)+a4_lat*Math.sin(4*latrad_lat)-a6_lat*Math.sin(6*latrad_lat)); var mlat_lat0=a*(a0_lat*lat0rad_lat0-a2_lat*Math.sin(2*lat0rad_lat0)+a4_lat*Math.sin(4*lat0rad_lat0)-a6_lat*Math.sin(6*lat0rad_lat0)); var e1_lat=nu_lat*omega_lat*Math.cos(latrad_lat); var e2_lat=nu_lat*omega_lat*omega_lat*omega_lat/6*Math.cos(latrad_lat)*Math.cos(latrad_lat)*Math.cos(latrad_lat)*(psi_lat-t_lat*t_lat); var e3_lat=nu_lat*Math.pow(omega_lat,5)/120*Math.pow(Math.cos(latrad_lat),5)*(4*psi_lat*psi_lat*psi_lat*(1-6*t_lat*t_lat)+psi_lat*psi_lat*(1+8*t_lat*t_lat)-psi_lat*2*t_lat*t_lat+Math.pow(t_lat,4)); var e4_lat=nu_lat*Math.pow(omega_lat,7)/5040*Math.pow(Math.cos(latrad_lat),7)*(61-479*t_lat*t_lat+179*Math.pow(t_lat,4)-Math.pow(t_lat,6)); var e_lat=k0*(e1_lat+e2_lat+e3_lat+e4_lat); var n1_lat=(omega_lat*omega_lat)/2*Math.cos(latrad_lat); var n1_lat0=n1_lat*nu_lat*Math.sin(latrad_lat); var n2_lat=(Math.pow(omega_lat,4)/24)*(Math.pow(Math.cos(latrad_lat),3))*(4*psi_lat*psi_lat+psi_lat-t_lat*t_lat); var n2_lat0=n2_lat*nu_lat*Math.sin(latrad_lat); var n3_lat=(Math.pow(omega_lat,6)/720)*(Math.pow(Math.cos(latrad_lat),5))*(8*Math.pow(psi_lat,4)*(11-24*t_lat*t_lat)-28*Math.pow(psi_lat,3)*(1-6*t_lat*t_lat)+psi_lat*psi_lat*(1-32*t_lat*t_lat)-2*psi_lat*t_lat*t_lat+Math.pow(t_lat,4)); var n3_lat0=n3_lat*nu_lat*Math.sin(latrad_lat); var n4_lat=(Math.pow(omega_lat,8)/40320)*(Math.pow(Math.cos(latrad_lat),7))*(1385-3111*t_lat*t_lat+543*Math.pow(t_lat,4)-Math.pow(t_lat,6)); var n4_lat0=n4_lat*nu_lat*Math.sin(latrad_lat); var n_lat=k0*(mlat_lat+nu_lat*Math.sin(latrad_lat)*(n1_lat+n2_lat+n3_lat+n4_lat)); var n_lat0=k0*mlat_lat0; var no=n_lat-n_lat0; var x=e_lat+x0*metconv; var y=(n_lat-n_lat0)+y0*metconv; // alert(n_lat); // alert("x="+x+"y="+y); // alert("a0="+a0_lat+"a2="+a2_lat+"a4="+a4_lat+"a6="+a6_lat); var xft=x/metconv; var yft=y/metconv; // alert("x="+xft+"y="+yft); return [xft,yft]; }
