how can I modify the Search Widget to stop zooming after a search and to pan if the searched item is outside the current extent?
I did the same in Flex...but with Web AppBuilder I don't understand where I have to modify...
Naty
Naty,
Sure it will require some code changes though:
In the [install dir]\server\apps\[app#]\widgets\Search\Widgets.js, find the _convertConfig function and add line 10 and the comma on 9:
def.resolve({ locator: new Locator(source.url || ""), outFields: ["*"], singleLineFieldName: source.singleLineFieldName || "", name: jimuUtils.stripHTML(source.name || ""), placeholder: jimuUtils.stripHTML(source.placeholder || ""), countryCode: source.countryCode || "", maxResults: source.maxResults || 6, useMapExtent: !!source.searchInCurrentMapExtent, autoNavigate: false });
If you want to do the same for feature layers as well then make these changes as well Line 12 and comma on 11:
var convertedSource = { featureLayer: flayer, outFields: ["*"], searchFields: fNames, displayField: source.displayField || "", exactMatch: !!source.exactMatch, name: jimuUtils.stripHTML(source.name || ""), placeholder: jimuUtils.stripHTML(source.placeholder || ""), maxResults: source.maxResults || 6, infoTemplate: template, useMapExtent: !!source.searchInCurrentMapExtent, autoNavigate: false };
Then in the _onSelectResult function add these line to the end of that function:
if(result.feature.geometry.type === 'point'){ this.map.centerAt(result.feature.geometry); }else{ this.map.centerAt(result.feature.geometry.getExtent().getCenter()); }
