I want to draw curved lines between points on the map using ArcGIS runtime sdk with android.Can i do that? Is there any inbuilt methods to do that? What are the inputs that wants to draw the curve rather than coordinates on the relevent points?
I am afraid there is no any built in method to draw curved lines. Here goes the workflow:
1. You might need to extend Symbol Class
2. Use SVG tags / geoJSON to hold geometries / coords
3. Draw curved lines on map using native android drawing capabilities
Your second option is have a look inside Milsym2525c lib from ESRI, It contains tactical graphic. They allow you to draw curved lines. I mean Green line from Wales to Irish sea.
Hope it would help
Thank you very much..If you can explain more the way that i should do from one of the options above it'll very helpful to me.
I read GeoJSON Earthquake Map and Mil2525c Sample on the sample code. But i couldn't find a way to draw curve.
I have some measurements like coordinates of the points where to place on the map, deflection angle between main tangents, radius tangent length etc. But i don't need to use all of those measurements..just some of them and draw the curve.Really i want to draw a railway path on the map.
I looked the Symbol class and in that the Curves only wants 3 points coordinates as start and end points coordinates and the control point coordinate to draw the curve. But here i'm only having start and end coordinates..
