Hi this is Pete. If you're using ArcGIS 10, you don't need my old VBA script anymore . You can calculate the area of polygon features directly in ArcMap. Just create an "Acres" field in your feature class, right-click that field in the Attribute table window, and select "Calculate Geometry". You should be able to choose "acres" as your unit of measure, and off you go!
