Private m_application As IApplication Public Overrides Sub OnCreate(ByVal hook As Object) If Not hook Is Nothing Then m_application = CType(hook, IApplication) 'Disable if it is not ArcMap If TypeOf hook Is IMxApplication Then MyBase.m_enabled = True Else MyBase.m_enabled = False End If End If ' TODO: Add other initialization code End Sub Public Overrides Sub OnClick() Dim SelectionForm As New myApp.SelectionForm Try If Not SelectionForm.Form_Initialize(m_application) Then Exit Sub SelectionForm.ShowDialog(New Win32HWNDWrapper(m_application.hWnd)) Catch ex As Exception MessageBox.Show(ex.Message, "OnClick") End Try End Sub
Public Class SelectionForm Private m_App As ESRI.ArcGIS.Framework.IApplication Private pMxDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument Private pEnumLayers As ESRI.ArcGIS.Carto.IEnumLayer Private pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer Friend Function Form_Initialize(ByVal m_application As ESRI.ArcGIS.Framework.IApplication) As Boolean Dim pLayer As ESRI.ArcGIS.Carto.ILayer Dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer2 m_App = m_application pMxDoc = CType(m_App.Document, ESRI.ArcGIS.ArcMapUI.IMxDocument) cboPointLayer.Items.Clear() cboField.Items.Clear() If pMxDoc.FocusMap.LayerCount > 0 Then pEnumLayers = pMxDoc.FocusMap.Layers pLayer = pEnumLayers.Next Do Until pLayer Is Nothing If pLayer.Valid Then If TypeOf pLayer Is ESRI.ArcGIS.Carto.IFeatureLayer Then pFLayer = pLayer If pFLayer.ShapeType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint Then cboPointLayer.Items.Add(pLayer.Name) End If End If End If pLayer = pEnumLayers.Next Loop End If Return True End Function Private Sub cboPointLayer_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cboPointLayer.SelectedIndexChanged Dim pLayer As ESRI.ArcGIS.Carto.ILayer Dim pFields As ESRI.ArcGIS.Geodatabase.IFields Try pEnumLayers.Reset() cboField.Items.Clear() pLayer = pEnumLayers.Next Do Until pLayer Is Nothing If pLayer.Name = cboPointLayer.Text Then pPointFLayer = New ESRI.ArcGIS.Carto.FeatureLayer pPointFLayer = pLayer Exit Do End If pLayer = pEnumLayers.Next Loop pFields = pPointFLayer.FeatureClass.Fields For i As Integer = 0 To pFields.FieldCount - 1 If pFields.Field(i).Type < 6 Then 'this adds only numeric, date, and string fields, not geometry, Blobs, raster, GUID, Global ID, or XML fields. cboField.Items.Add(pFields.Field(i).Name) ListBox1.Items.Add(pFields.Field(i).Name) End If Next EnableRun() Catch ex As Exception Messagebox.Show(ex.message, "Point Layer") End Try End Sub End Class
