Ok, I've found a solution for the next ones facing that issue : you need to publish your service from ArcMap (don't ask me why)
Alex.
Hi Zachary,
I've got exactly the same issue on AGS 10.3.1, exactly the same and I'm knocking my head against the wall.
No warning with data store properly registered and ArcGIS Server that keeps uploading the gdb in the v101 folder with no warning about data that will be uploaded.
Were you able to fix that issue ?
I can't reproduce this (I'm responsible for testing NIM087822 and assigning to a developer).If you have a minute can you look at the attached word doc. Is there anything you've done differently compared to my workflow?If there is indeed a bug here (as I've done something differently than you), I'd like to get it addressed for the next service pack. However that window is quickly closing so any information you can provide would be great.
That is right, it basically makes feature service not editable when using sql express in server 10.1.
No... it will only copy the data if it doesnt find a match in the datastore.If you can publish a map service and that data doesnt get copied, then the datastore is setup correctly.I've never heard anyone report this particular issue you're running into: not warned about data being copied, but then the data is copied.You said you logged a support incident? Whats the incident #? I want to look up the notes and see if anything stands out.
I can read till 'regardless'.....what a drag.ok, now with a 'real' browser i can read the rest of what Kevin posted. It seems to suggest that at 10.1 GP services copy data to the server no matter what? Even then, my problem is still with the published model. The output references that file gdb published to the server, not my SDE connection.
interesting. So for the heck of it, i changed my registered SQL Express DB connection information to just the name of the instance... without \sqlexpressI can see the correct gdb and it validates fine. Now i re-run my model and when i try to publish the results i'm warned about data getting copied to the server.
