1. Is it ok that both layers before the intersect are in WGS (although the data file manual says it is in ETRS)?
2. Or do you mean that before the intersect, that both layers need to be in the UTM projection instead of the WGS?
LAYER 1: The European regions layer contained all the surface areas
1. My colleague told me that it wasn't necessary to change to a UTM projection to calculate the regions surface area, what is your experience?
2. If my projections would have been correct, would I still need to recalculate geometry or should the calculation after the intersect be correct automatically?
