Just ran across this thread. Maybe it will help you:http://forums.arcgis.com/threads/26850-Sleeping-Server-Services-slow-to-start
Sad to say, I am still getting this 2032 error. I'm really at a loss on what to do as I have tried all suggestions, but this intermittent error still occurs. I never saw this error until I upgraded flexview to 2.4 and 2.5 and its really causing issues with my users as the get errors on the services as they load (normally the first time of the day)Anyone from ESRI have any suggestions on how to resolve this error ?Here are the steps I have taken now:1. Modified the IIS settings on the HTTP Header to must-revalidate for the default website2. Changed the Server to Periodically check and repair data connections for idle instance every 30 minutes3. Restart all services at 6am daily.4. Added .SWZ files to the Mime per the FAQ for ArcGIS Viewer for FlexThank you,Matt
Thanks for the tip on the must-revalidate. I was able to apply this to the Default Web Site without the error 500. Hopefully this will be the fix.Matt
Matt,I added the cache-control to just the Default Web Site. Also, once I added this control, I was unhappy with the speed of the site, it slowed down considerably. I ended up using Cache-Control: must-revalidate instead. Completely forgot I made that change until I checked the server settings.Ashley
Try making the changes to the HTTP header for the default web site.
