<?xml version="1.0"?> <configuration label=""> <description/> <taskurl>http://172.16.1.132/ArcGIS/rest/services/HotSpot_Adjustable/GPServer/HotSpot</taskurl> <helpurl>http://server01/arcgisoutput/HotSpot_Adjustable/HotSpot.htm</helpurl> <inputparams> <param name="Jenayah" label="Jenayah" required="true" type="string" visible="true"> </param> <param name="Pilih_PBT" label="Pilih PBT" required="true" type="string" visible="true"> </param> <param name="Pilih_Bulan" label="Pilih_Bulan" required="true" type="string" visible="true"> </param> <param name="Clip_Sempadan_PBT" label="Sempadan_PBT" required="true" type="string" visible="true"> </param> <param name="Use_Input_Features_for_Clipping_Geometry" label="Use Input Features for Clipping Geometry" required="true" type="string" visible="true"> </param> </inputparams> <outputparams> <param name="Hasil_Hot_Spot" geometrytype="featurerecordset" label="Hasil_Hot_Spot" required="true" type="rasterdatalayer" visible="true"><!-- <renderer type="simple"> <defaultsymbol alpha="0.5" color="0xFF00FF" type="simplefill"> <outline width="1" color="0x000000"/> </defaultsymbol> </renderer> --> </param> </outputparams> <layerorder>Base,Hasil_Hot_Spot</layerorder> </configuration> -->
else if (resultDataType == GPParameterTypes.GP_RASTER_DATA_LAYER) { var jobInfo:JobInfo = gp.submitJobLastResult; if (jobInfo) { var resultImageLayer:GPResultImageLayer = gp.getResultImageLayer(jobInfo.jobId, parameterValue.paramName); map.addLayer(resultImageLayer); } }
Currently, adding raster images to the map is not supported. The default behavior is to download the result image.Do you have a map service associated with your geoprocessing service?
Mohd, Have you tried rasterdatalayer as the output type?
