Does anyone know how i might solve this issue
When you load your point layer as "demand" for a location-allocation layer, you can map in the field that contains your allocation weighting as "Weight". See the attached screen shot that maps the field POP2000 to the weight property.
Similarly you can map in the "Capacity" for the Facilities. Make sure to use the "Maximize Capacitated Coverage" problem type to solve with capacity.
Jay Sandhu
Hi Jay, Thanks a lot.
