Create custom Windows applications with power mapping and GIS capabilities. It includes an interactive samples application, sample data, developer help, and other resources to help you build and deploy your own custom solution using Microsoft's WPF technology. For details, see http://esriurl.com/4496.
Hi,Does version 1.0 of ArcGIS Runtime SDK for WPF contain API for developing Metrostyle applications (Windows 😎 as demonstrated in Developers Summit?Best Regards, Dima.
No it doesn't, that is developed in totally different product line. Actually current download does not support Visual Studio 12 at all since it requires Visual Studio 2010 SP 1 installed. Haven't tested if I can install current build to machine with both 2010 and 2012 and then use Runtime in 4.5 projects at VS 2012. If someone has done that, did it work or is there coming VS2012 version with 4.5 support?
I tried it, but it's impossible even to add reference to Runtime SDK in Metrostyle application.
The current WPF SDK is now the version 10.2.3. It can be downloaded from here.
If you start a new project you should also consider using the new .Net API.
