def i(x): if x is None: return "Used to be Null" else: return x
import arcpy, os arcpy.env.workspace = "Z:\myTest.gdb" #path to your geodatabase rows = arcpy.UpdateCursor("test") #test is the name of the feature class you wish to work with for row in rows: if row.test1 == None: #test1 would be the name of the field in the feature calss row.test1 = "Used to be Null" rows.updateRow(row) del row del rows
rows = arcpy.UpdateCursor(layer) for row in rows: var = row.AREAESTIMATED if var: row.TAG = 1 else: row.TAG = 0 rows.updateRow(row)
def i(x): var = x if var: return var else: return "not null anymore"
def i(x): var = x if var: return "Used to be Null" else: return var
