I would like to reference this https://data.lacity.org/resource/4iim-t2y2.json in my web map. Can someone guide on how this is done?
https://community.esri.com/community/developers/web-developers/arcgis-online-developers
Can you expand on this? Do you want all features to point to that? Or is there separate JSON for each item?
All features. I got it from this website: https://data.lacity.org/A-Livable-and-Sustainable-City/Storm-Drain-System/pjh9-xwfn/data by selecting export, SODA API, and copying the API endpoint. Is this possible to add to ArcGIS Online? I couldn’t do it using any of the standard ways in a web map.
If you want to have the raw JSON, you can always make custom pop-ups and point to this URL : https://data.lacity.org/api/views/4iim-t2y2/rows.json
If you're looking to selectively parse the JSON for each feature, you'll need to write some custom code (python will do the trick).
Another option is to download this as a CSV, add it to your AGOL organization and point it to that URL.
Am I understanding your request properly? You just want users to be able to get to that json URL from the web map in some way? If so, custom pop-ups is the way to go
Hi Andrew,
I actually want to just display the layers attached to this json in my own web map. Specifically these layers: https://data.lacity.org/A-Livable-and-Sustainable-City/Storm-Drain-System/pjh9-xwfn/data
Brandon
Is that possible or even harder? Than the popup?
Oh! And is this data constantly changing or would a static copy suffice?
Static would be in the worst case. I would preferably have it streaming in case it changes. I would guess the changes are not often.
If it's static, you can download the GeoJSON from the site and then import that as a hosted item into you content. Then, from there, you can add it to your map as an item. That will be static, however.
I'll do a little digging for dynamism, but that is a temporary solution
Sounds good. Thanks for the help. I will try on my end too.
I took a step back and looked backwards and found that LA County actually maintains this information as a typical REST service: sds_mobile (MapServer) (or in an AGOL map here: http://www.arcgis.com/home/webmap/viewer.html?webmap=c62ae2f244f04e8086c89e8db3f530d8 )
Check that out and let me know if that meets your needs
I have seen this map service before. This is the one I am currently using in my web map. I thought the one at
https://data.lacity.org/A-Livable-and-Sustainable-City/Storm-Drain-System/pjh9-xwfn/datamight have more features for some reason at a glance. Looks like they might be the same. Thanks for all your help Andrew.
