The code returns me an error Runtime error <type 'exceptions.IOError'>: UNKNOWNlayerName=r'M:\UTILISATEURS\Pierre\SERAIL\MISE_A_JOUR.gdb\TEST'I work from a class annotation. I don�??t want to change the data source, but simply change the label expression or display rather like my data is a class annotation.
layerName='TEST'
Function FindLabel ( [TextString] ) Label = replace([TextString], "Ec.", "Ecole") Label = replace(Label, "Egl.", "Eglise") Label = replace(Label, "Text to search for", "Text to replace it with") 'etc FindLabel = Label End Function
Hello,I work on a table of about 1200 objects. I wonder if it is possible to write a standalone Python script to replace one word with another without changing the values �??�??of my table. As building label expressions.Exemple:I would like to replace Ec. for Ecoleother exempleI would like to replace Egl. for EgliseThanks for your help
import arcpy mxdPath = r"C:\Project\_LearnPython\Ohio2.mxd" layerName = "OH30" fldName = "yourLabelFieldName" # in case of shapefile of personal geodatabase labelExpression = 'replace(replace([{0}],"Ec.","Ecole"),"Egl.","Eglise")'.format(fldName) # in case of file geodatabase # labelExpression = 'replace(replace("{0}","Ec.","Ecole"),"Egl.","Eglise")'.format(fldName) mxd = arcpy.mapping.MapDocument(mxdPath) for lyr in arcpy.mapping.ListLayers(mxd): if lyr.name == layerName: if lyr.supports("LABELCLASSES"): lyr.showLabels == True for lblClass in lyr.labelClasses: lblClass.expression = labelExpression mxd.save() del mxd
