What�??s new at 1.2:* Structure definitions for curves (CircularArcCurve, BezierCurve, EllipticArcCurve).
namespace FileGDBAPI { /*----------------------------------------------------------------------------- Curve structure definition, from Extended Shape Buffer Format, February 9, 2012 (doc\html\extended_shape_buffer_format.pdf) The document uses "long" for some members, but we use int32 (from FileGDBCore.h) here to ensure a fixed size. (The necessary size of a "long" can be deduced from footnote 12.) */ #pragma pack(push, 1) struct WKSPoint { double x, y; }; struct SegmentArc { union { WKSPoint centerPoint; // If IsPoint is 0. Also, it is ignored if // IsLine is 1. double angles[2]; // If IsPoint is 1: start and central angle // centerPoint = endPoint }; int32 Bits; // Contains, among others, bits for IsPoint, IsLine ... }; struct esriSegmentModifier { int32 startPointIndex, /* enum esriSegmentType */ segmentType; union { SegmentArc arc; SegmentBezierCurve bezierCurve; SegmentEllipticArc ellipticArc; // SegmentOther otherKindsOfSegment; // ... } segmentParams; }; ... #pragma pack(pop) } // namespace FileGDBAPI // Build a vector of curves from my input data vector<esriSegmentModifier> vCurves; for (...) { esriSegmentModifier modifier; modifier.startPointIndex = ... modifier.segmentType = esriSegmentArc; modifier.segmentParams.arc.centerPoint.x = ... modifier.segmentParams.arc.centerPoint.y = ... modifier.segmentParams.arc.Bits = ... vCurves.push_back(modifier); } // Put the curves into a MultiPartShapeBuffer for the database MultiPartShapeBuffer polyline; ... if (vCurves.size() != 0) { byte* curve; polyline.GetCurves(curve); for (vector<esriSegmentModifier>::const_iterator iter = vCurves.begin(); iter != vCurves.end(); ++iter) { // SegmentArc is the only curve supported by this code assert(iter->segmentType == esriSegmentArc); // copy the data from my vector to the ShapeBuffer esriSegmentModifier* modifier = reinterpret_cast<esriSegmentModifier*>(curve); *modifier = *iter; curve += offsetof(esriSegmentModifier, segmentParams) + sizeof(SegmentArc); } } polyline.CalculateExtent(); polyline.PackCurves(); row.SetGeometry(polyline); }
