I have been using Add Geometry sucessfully for a period of time and now today the tool will not run. M y work flow is straight forward: Polyline converted to equal segment lengths ( Split Line - date management) then split lines through add geometry to determine bearing of each segment. I get the following error message. I have looked at the python (I am not very conversant) script, but I cannot see where the problem is. Any help would be appreciated.
Thankyou
Messages
Executing: AddGeometryAttributes "C:\Users\Brian Knelller\Documents\ARCGIS\Mars_Working_Template\Mars_GeneralGeo.gdb\FluvialCorridor_Channel_11_Complete\Channel_11_Complete_LRA_LOWER_SPLIT" LINE_START_MID_END;LINE_BEARING # # PROJCS['Mars2000_EquidistantCylindrical_CLON0',GEOGCS['GCS_Mars_2000_Sphere',DATUM['D_Mars2000_Sphere',SPHEROID['Mars2000_IAU_IAG_Sphere',3396190.0,0.0]],PRIMEM['Reference_Meridian',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Equidistant_Cylindrical'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',0.0],PARAMETER['Standard_Parallel_1',0.0],UNIT['Meter',1.0]]
Start Time: Sat Apr 23 19:11:18 2016
Running script AddGeometryAttributes...
Failed script AddGeometryAttributes...
File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Scripts\AddGeometryAttributes.py", line 292, in <module>
AddGeometryAttributes(fc, geomProperties, lUnit, aUnit, cs)
File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Scripts\AddGeometryAttributes.py", line 49, in AddGeometryAttributes
fields = CreateOutputFields(fc, geomProperties, hasZ, hasM)
File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Scripts\AddGeometryAttributes.py", line 244, in CreateOutputFields
arcpy.da.ExtendTable(fc, "OID@", narray, "_ID")
RuntimeError: General function failure [Channel_11_Complete_LRA_LOWER_SPLIT]
Failed to execute (AddGeometryAttributes).
Failed at Sat Apr 23 19:11:20 2016 (Elapsed Time: 1.69 seconds)
