I create 100 polygon features in map,then i print the map with the features,But I run the printTask , the server is collapse; I create 20 polygon the print the result is ok. the number for printTask is limit?
I use the arcgis api for js 3.17!
function ShowByZhen(id) {
var queryTask = new esri.tasks.QueryTask("http://192.168.20.1:6080/arcgis/rest/services/zhen/MapServer/0");
var query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["*"];
query.where = "1=1";
queryTask.execute(query, ShowByZhen_ShowResults);
queryTask.on("error", queryTaskErrorHandler);}
function ShowByZhen_ShowResults(results) {
// var symbol = new esri.symbol.SimpleFillSymbol().setColor(new esri.Color([205, 192, 197,0.5])).outline.setColor(new esri.Color([189, 0, 38, 0.5]));
var symbol = new esri.symbol.SimpleFillSymbol().setColor(new esri.Color([205, 193, 197, 0.5]));
var fss = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new esri.Color([205, 192, 197]), 2),
new esri.Color([255,255,0,0.25]));
alert(results.features.length);
var resultCount = results.features.length;
for(var i=0;i<resultCount;i++)
var mFeature = results.features;
var mFeatureAttribute = results.features.attributes;
mFeatureAttribute["moneyfinish"] = 10000*i;
if (i < 130) {
mFeature.symbol = fss;
map.graphics.add(mFeature);
function Print() {
var printUrl="http://192.168.20.1:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"
printTask = new esri.tasks.PrintTask(printUrl, { async: true });
params = new esri.tasks.PrintParameters();
params.map = map;
//*****print
var ptemplate = new esri.tasks.PrintTemplate();
ptemplate.layout = "A3 Landscape";
// ptemplate.layout = "MAP_ONLY";
ptemplate.format = "jpg";
ptemplate.layoutOptions = {
legendlayers: [],
scalebarUnit: "Meters",
titleText: Titletxt
// use the extent of the webmap in the output PDF
ptemplate.preserveScale = false;
params.template = ptemplate;
// params.template = "A3 Landscape";
printTask.execute(params, printComplete);
