It seems that you would want a function that creates a custom envelope. The input would be the envelope for the point and inside the function it would compare each value of the part of the envelope (xmin, ymin, etc.) with that of the city boundary and assign the more extreme value to the new envelope. This way the smallest value for a min and largest value of max will be used to expand the envelope when the point is outside the city boundary.
Is your city boundary geometry sent to the client? If so, you can do the following:-create an esri.geometry.Polygon from your city boundary-use polygon.contains() to test if your point is in your city boundary-if the point is in your polygon, set the map extent to the city boundary's extent-if the point is not in your polygon, create an extent from your point-union your point extent with the extent of your city boundary-set the map's extent to the unioned extent
// point objects don't have an extent so you need to // calculate a small value to use as padding for your point var px = (map.extent.xmax - map.extent.xmin) / map.width // then create an extent var ptExtent = new esri.geometry.Extent( pt.x - px, // xmin pt.y - px, // ymin pt.x + px, // xmax pt.y + px, //ymax map.spatialReference ); // union the two extents // cityExtent would be the result of // cityGraphic.getExtent() var newExtent = ptExtent.union(cityExtent); map.setExtent(newExtent);
Hi Chris,Thanks for posting the video, very helpful.If I have this right, your city boundary is a dynamic map service layer? I was thinking it was a graphic on your map and not an overlay. Any chance you're willing to move to using your city boundary as a graphic instead of a dynamic map service layer?To answer your question about the union method I mentioned, you need two extent geometries so you would need to create an extent from your point. Here's one method: // point objects don't have an extent so you need to // calculate a small value to use as padding for your point var px = (map.extent.xmax - map.extent.xmin) / map.width // then create an extent var ptExtent = new esri.geometry.Extent( pt.x - px, // xmin pt.y - px, // ymin pt.x + px, // xmax pt.y + px, //ymax map.spatialReference ); // union the two extents // cityExtent would be the result of // cityGraphic.getExtent() var newExtent = ptExtent.union(cityExtent); map.setExtent(newExtent);
Since you can see what I am attempting, the next question is, how to modify my code. I have no problem with using the city boundary as a graphic. It serves no purpose besides display.Please let me know if I need to explain anything.Here is my code. I have quite a few comments, so hopefully it will answer any questions about how it works. Limited comments are when I am using an ESRI example; which did not really explain what was being done; this is just to explain gaps in my documentation.I have the code for the entire app at: http://dl.dropbox.com/u/26169505/CityHireEligibleSample.zipIt's 3.94mb ESRI's limit is 2.0mb It's a public URL, so you do not need to have a dropbox account. I will remove this file when you download it or tomorrow.Thanks for your feedback. I will attempt to modify my code, but if you see what I need to do, that would be great too.Chris
function showBuffer(geometries) { var symbol = new esri.symbol.SimpleFillSymbol( esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol( esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 255, 0.65]), 2 ), new dojo.Color([0, 0, 255, 0.35]) ); dojo.forEach(geometries, function (geometry) { var graphic = new esri.Graphic(geometry, symbol); map.graphics.add(graphic); }); // looks like you only buffer one point // so take the first geometry in the geometries array // and get its extent var bufferExtent = geometries[0].getExtent(); // create a new extent that is the union of the buffer's // extent and the map's current extent var newExtent = bufferExtent.union(map.getExtent()); // set the map's extent map.setExtent(newExtent); queryParams.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERIORINTERSECTION; queryParams.returnGeometry = true; queryParams.geometry = geometries[0]; queryTask.execute(queryParams); }
Hey Chris, Thanks for posting another video, that makes it crystal clear to see what you're trying to do. I'm going to suggest a slightly new idea...since you're adding a buffer to your map, how about setting your map extent to include the buffer and the city boundary? To do this, you would take the extent of your buffer geometry, union it with your map extent and then set your map extent to the new extent. I'm looking at the code you uploaded yesterday and you would do this inside your "showBuffer" function. Here's how it would look: function showBuffer(geometries) { var symbol = new esri.symbol.SimpleFillSymbol( esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol( esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 255, 0.65]), 2 ), new dojo.Color([0, 0, 255, 0.35]) ); dojo.forEach(geometries, function (geometry) { var graphic = new esri.Graphic(geometry, symbol); map.graphics.add(graphic); }); // looks like you only buffer one point // so take the first geometry in the geometries array // and get its extent var bufferExtent = geometries[0].getExtent(); // create a new extent that is the union of the buffer's // extent and the map's current extent var newExtent = bufferExtent.union(map.getExtent()); // set the map's extent map.setExtent(newExtent); queryParams.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERIORINTERSECTION; queryParams.returnGeometry = true; queryParams.geometry = geometries[0]; queryTask.execute(queryParams); }
