Can I take a Flex Viewer project and convert it to flash builder so that I can use it on an iPad or Android device and then customize how I want?
Is it possible to run the ArcGIS Viewer for Flex application on my iPhone or iPad?No. There are two specific issues with this.The ArcGIS Viewer for Flex is a standard Flex project, therefore, it would need to be written as a Flex Mobile Project.The ArcGIS Viewer for Flex uses Flex modules. These are not supported in mobile projects.
I'm just looking for an easy to use starting template that has a nice Table of contents, Navigation bar (You know the basic map interface stuff) . .
Michael,You are really confusing me with what you are after as the whole flex application is configurable so you can add or remove widgets as you see fit. Web applications are opened via a web address so not quite sure what you mean about not being able to create a site in flash builder.What is it you are trying to achieve?RegardsAnthony
