It may be that your selection tables have not been built.Depending on how you set up server you may have user specific or global selection tables in ArcSDE (the ones ArcMap uses when the user selects over 100 records)Go to ArcMap and load the layers that you have been using for your service, then do a big selection (i.e. over 100 features). This will cause ArcGIS to build these tables (ArcGIS Mobile won't, just hangs).Once you do this try posting, it should work for youK
Nicolas,have you solved your problem? I have same problem on the same version of ArcGIS Server.Can you help me please?Thank you very much.Ivan
Hello,I have also a mobile upload error but it is a different one : "Fatal error from the server".The download is working but not the upload.When I check on the server's journal, I have the following message : "MobileSync: Post Features Failure" concerning the following method :"MobileSync.UploadFeatures".I precise that I am working on ArcGIS mobile 10.1.1 and ArcGIS server 10.1.I am working with an NOT-versionned ArcSDE database.Data have a GlobalID Field and are registered to the ArcGIS Server.There is no security option to my mobile service (http with no -s and so no identification required for downloading the data and I suppose for uploading but maybe the problem come from there, I don't know).Also, after reading the thread 54005, where the same error was mentionned, I checked the permission and it is public so the problem does not come from there.If you have any idea, please let me know !Thanks !
