using System; namespace GeoEdit { public partial class MainPage : UserControl { Locator _locatorTask; GraphicsLayer _candidateGraphicsLayer; private static ESRI.ArcGIS.Client.Projection.WebMercator _mercator = new ESRI.ArcGIS.Client.Projection.WebMercator(); public MainPage() { InitializeComponent(); ESRI.ArcGIS.Client.Geometry.Envelope initialExtent = new ESRI.ArcGIS.Client.Geometry.Envelope( _mercator.FromGeographic( new ESRI.ArcGIS.Client.Geometry.MapPoint(-82.23, 41.48)) as MapPoint, _mercator.FromGeographic( new ESRI.ArcGIS.Client.Geometry.MapPoint(-82.15, 41.4)) as MapPoint); initialExtent.SpatialReference = new SpatialReference(102100); MyMap.Extent = initialExtent; _candidateGraphicsLayer = MyMap.Layers["PointLayer"] as GraphicsLayer; } private void FindAddressButton_Click(object sender, RoutedEventArgs e) { _locatorTask = new Locator("http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Streets_US_10/GeocodeServer"); _locatorTask.AddressToLocationsCompleted += LocatorTask_AddressToLocationsCompleted; _locatorTask.Failed += LocatorTask_Failed; AddressToLocationsParameters addressParams = new AddressToLocationsParameters() { OutSpatialReference = MyMap.SpatialReference }; Dictionary<string, string> address = addressParams.Address; if (!string.IsNullOrEmpty(InputAddress.Text)) address.Add("Street", InputAddress.Text); if (!string.IsNullOrEmpty(City.Text)) address.Add("City", City.Text); if (!string.IsNullOrEmpty(State.Text)) address.Add("State", State.Text); if (!string.IsNullOrEmpty(Zip.Text)) address.Add("ZIP", Zip.Text); _locatorTask.AddressToLocationsAsync(addressParams); } private void LocatorTask_AddressToLocationsCompleted(object sender, ESRI.ArcGIS.Client.Tasks.AddressToLocationsEventArgs args) { CandidateListBox.Items.Clear(); List<AddressCandidate> returnedCandidates = args.Results; foreach (AddressCandidate candidate in returnedCandidates) { if (candidate.Score >= 80) { CandidateListBox.Items.Add(candidate.Address); Graphic graphic = new Graphic() { Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol, Geometry = candidate.Location }; graphic.Attributes.Add("Address", candidate.Address); string latlon = String.Format("{0}, {1}", candidate.Location.X, candidate.Location.Y); graphic.Attributes.Add("LatLon", latlon); if (candidate.Location.SpatialReference == null) { candidate.Location.SpatialReference = new SpatialReference(4326); } if (!candidate.Location.SpatialReference.Equals(MyMap.SpatialReference)) { if (MyMap.SpatialReference.Equals(new SpatialReference(102100)) && candidate.Location.SpatialReference.Equals(new SpatialReference(4326))) graphic.Geometry = _mercator.FromGeographic(graphic.Geometry); else if (MyMap.SpatialReference.Equals(new SpatialReference(4326)) && candidate.Location.SpatialReference.Equals(new SpatialReference(102100))) graphic.Geometry = _mercator.ToGeographic(graphic.Geometry); else if (MyMap.SpatialReference != new SpatialReference(4326)) { GeometryService geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); geometryService.ProjectCompleted += (s, a) => { graphic.Geometry = a.Results[0].Geometry; }; geometryService.Failed += (s, a) => { MessageBox.Show("Projection error: " + a.Error.Message); }; geometryService.ProjectAsync(new List<Graphic> { graphic }, MyMap.SpatialReference); } } _candidateGraphicsLayer.Graphics.Add(graphic); } } if (_candidateGraphicsLayer.Graphics.Count > 0) { CandidatePanelGrid.Visibility = Visibility.Visible; CandidateListBox.SelectedIndex = 0; } } void _candidateListBox_SelectionChanged(object sender, SelectionChangedEventArgs e) { int index = (sender as ListBox).SelectedIndex; if (index >= 0) { MapPoint candidatePoint = _candidateGraphicsLayer.Graphics[index].Geometry as MapPoint; double displaySize = MyMap.MinimumResolution * 30; ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope( candidatePoint.X - (displaySize / 2), candidatePoint.Y - (displaySize / 2), candidatePoint.X + (displaySize / 2), candidatePoint.Y + (displaySize / 2)); MyMap.ZoomTo(displayExtent); } } private void LocatorTask_Failed(object sender, TaskFailedEventArgs e) { MessageBox.Show("Locator service failed: " + e.Error); } private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args) { FeatureLayer featureLayer = sender as FeatureLayer; for (int i = 0; i < featureLayer.SelectionCount; i++) featureLayer.SelectedGraphics.ToList().UnSelect(); args.Graphic.Select(); MyFeatureDataForm.GraphicSource = args.Graphic; FeatureDataFormBorder.Visibility = Visibility.Visible; } private void EditorWidget_Loaded(object sender, RoutedEventArgs e) { string[] myLayerIDs = { "PointLayer" }; MyEditorWidget.LayerIDs = myLayerIDs; } } }
var g = new Graphic(); g.Geometry = geocodeResult; foreach (var f in l.LayerInfo.Fields) g.Attributes[f.Name] = null; l.Graphics.Add(g); var childWindow = new ChildWindow(); var fdf = new FeatureDataForm() { FeatureLayer = l, GraphicSource = g }; childWindow.Content = fdf; childWindow.Show();
g.Attributes["Date"] = DateTime.Now; g.Attributes["Job_Location"] = InputAddress.Text;
var fdf = new FeatureDataForm() { FeatureLayer = layer, GraphicSource = graphic}; var window = new ChildWindow() { Content = fdf }; fdf.EditEnded += (a, b) => { window.Close(); }; window.Show();
//g.Attributes["Job_Type"] = "2"; //g.Attributes["Job_Type"] = "'2'"; //g.Attributes["Job_Type"] = "Broken Valve"; //g.Attributes["Job_Type"] = "'Broken Valve'";
STATUS ( type: esriFieldTypeSmallInteger , alias: Status , editable: true , nullable: true , Coded Values: [1: New] , [2: Open] , [3: Closed] )
graphic.Attributes["STATUS"] = 1;
It depends on your service. For example, this service defines its coded value domain as:This feature attribute will then be:graphic.Attributes["STATUS"] = 1;where datatype is Int16 and is one of the possible code 1, 2, 3.http://servicesbeta2.esri.com/arcgis/rest/services/SF311/FeatureServer/0/1
g.Attributes["Job_Type"] = 1;
